Can I safely put my VW (Passat 1.8L turbo) oil filters on my Nissan Sentra?
Here's what Wix says the specs are:
Application: Passat
Part Number: 51088
UPC Number: 765809510883
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.704
Outer Diameter Top: 2.983
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 30
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.740 2.370 0.275
Application: Sentra (1992 w/E16i)
Part Number: 51361
UPC Number: 765809513617
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.067
Outer Diameter Top: 2.960
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: None
Gasket Diameters
Attached 2.475 2.173 0.233
Application: Passat
Part Number: 51088
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.704
Thread Size: 3/4-16
Gasket Diameters
Part Number: 51361
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.067
Thread Size: 3/4-16
Gasket Diameters
