- Joined
- Sep 28, 2002
- Messages
- 39,793
51394 in Wix is what you are supposed to have
Part Number: 51394
UPC Number: 765809513945
Principal Application: GM (85-05), Daihatsu (88-92), Infiniti (91-96), Kawasaki Mules, Nissan (91-95), Toyota (80-05), Scion (04-05)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.977
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Here's what the Camary gets.
Part Number: 51396
UPC Number: 765809513969
Principal Application: GM Vehicles (99-05), Geo (89-92), Suzuki (96-05), Toyota (88-05), Various Ford-New Holland Tractors
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Thread Size: 3/4-16
Gasket Diameters
It's just about 1/2" longer.
So, if the OEM contours the Wix line, and assuming there is no mounting room issues, then yes.
Part Number: 51394
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.977
Thread Size: 3/4-16
Gasket Diameters
Part Number: 51396
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Thread Size: 3/4-16
Gasket Diameters
