Is it correct for me to assume that a lower winter weight (0w, 5w) oil is more likely to be burned by an engine that's burning a bit of oil compared to a higher (10w, 15w) winter weight oil?
It is not correct. Why would that be the case?
I think it's a pretty obvious and common stream of logic for someone to assume that a thinner oil is more likely to get into the combustion chamber and burn. Plenty of people believe this is the case, as you can see through a Google search and a quick viewing of various car forum posts across the internet. So I can assume that Castrol Edge 0w40 (13.5 at 100c) will be only negligibly more likely to burn compared to the 10w40 M1HM (14.71 at 100c) I'm using due to a difference of viscosity (kinematic at 100c) of 1.2? Or is that a very big difference? It would seem that the Edge 0w40 is a bit thin compared to some other 40 weights, but I'm totally open to switching over without any more oil concerns ever again, for this car, if it burns at the same rate as what's currently in there. Why do 5w, 10w and 15w synthetic oils exist at all if 0w30 and 0w40 oils can be purchased for roughly the same price? (That's a serious question, by the way.) I would imagine that a quicker flowing oil at cold temps is
always better. Why use 5w30 in a car when you could use 0w30? Assuming they're the same price. Most of these oils are roughly $25 per 5 quart jug at Walmart.
Thanks to another couple of members for covering BMW's temp/visc chart as well as what makes D1 the superior oil as compared to T6 or TDT.
To the OP, around here, D1 is priced the same as TDT. Both have the same $12.00/jug MIR ATM.
I've recently bought D1 for less than eight bucks per gallon jug with store deals and the MIR.
There is no way on God's green earth that I'd recommend any oil at the prices you've quoted for D1.
T6 is a little cheaper, but SOPUS offers only a miserly MIR that you might have to waste time calling for after their opening bid denial anyway.
Indeed, thanks to the people who posted the charts.
The Delvac 1 goes for the price I mentioned online, but I wouldn't hesitate to try it if I found it for the same price as TDT. I was completely floored when I saw the price locally, all the way to the point of asking the manager at the truck stop to check on the computer to see if that price was correct.
