What conditions in the Winter (perhaps besides extreme cold) are harder on an oil and thus why more people run a synthetic at least during the Winter months ?
I would tend to think that frigid temps are the main reason for startup protection. Winter also means dirty roadways Salt/Sand/Chemicals etc. Does not hurt to have the most protection during the winter.
Originally Posted By: ChrisD46
is there a correlation to colder temps and fuel dilution to motor oil ?
There is. When it's cold outside, the engine takes longer to reach normal operating temp, and until it does reach it, it runs rich which in turn may cause more fuel to get dumped into the oil.
There is also a possibility of having more moisture in the crankcase in winter since engine may not get up to proper operating temp and stay there long enough to evaporate it. That's when you see the mayo-looking stuff on your oil cap.
Now, you're in GA, so don't talk to me about winter.
I've read in more than a few places, that extreme cold actually starts raising the pour point of oil significantly. I think its more an issue for lightly used heavy equipment that may have motor oil in it for a couple years and perhaps many years on the hydraulic fluid.
I still store my stach in the shed but it all has quite a ways to go before cold flow becomes an issue.
Inadequate warmup time leaving moisture in the water. It doesn't hurt the oil but might damage engine (rust). I never killed an engine but did rust-out a catalyst in just one year with short 10 minute trips. I now drive my car at least 30 minutes after it reaches hot temp.
Yes , cold start up not as much a problem in GA. but still interested in what my Northern BITOG brothers have to contend with ...You never stop learning !
I realize you can drive about 20 miles or so and get the engine to temperature to burn off all the moisture in the oil, but can you do the same for fuel dilution? Or is the fuel there to stay until the next oil change?
