Windows RUN (tool) troubleshoot
Triple_Se7en
$50 Site Donor 2024
Lower SE Michigan
Ever since I loaded the most recent Windows 10 Anniversary Update, the blank white box used to type text commands for System Configuration results does not save what I type. A most recent command-example is the commonly used MSCONFIG.
BTW..... I have Classic Shell Start Menu 4.3 installed. I access ''RUN'' thru it.
Thanks in advance for any help in this matter.
Finally solved the dilemma. For anyone with this concern, try this fix.
The location of this setting has changed in Windows 10. 1.Open the Start menu 2.Select Settings 3.Select the Personalization button 4.Select Start in the left column 5.Toggle Show most used apps to the On position.
