Of course they are. I dont mind learning new things, but it feels like...its made intentionally difficult? I know thats not right..
So, I went an used it. I fired it up in VMWare again. Release Preview, btw.
Some things aren't intuitive is an understatement.
First thing was, the network wasnt connected, so I went to try to investigate.
I hovered over the right side to try to bring up the thing. After I got it to cooperate I hit 'Settings' then 'Network'.
I get there and see 'Network Limited' I click it and it bumps. The line of text and icon representing the connection get smaller for a split second, but otherwise nothing happens.
I'm Going, "What? Then what is this #%$#$ even for?"
I right click and get, 'Turn Sharing On or Off'? Thats it?
Now Im starting to overheat, "So, pretty much this whole menu is a worthless sack of #@#%#%^%@?"
So I attempt to go back and hit the word 'Networks' which is next to the back arrow. Actually, I didnt even read the actual word. Im just used to words next to a button being part of the button and thought it would bring me back. It of course did nothing, which only aggravated me further.
Once I read it though, I found it redundant. Its placement next to the back arrow makes me think it should indeed bring me back to Settings, but then again, Im in Networks right now. Then, right under that, it says 'Connections'? Isnt that the same thing? Why not have 'Settings' next to the back arrow, and under it 'Networks' like a tree? So you know you are in 'Networks' and back is 'Settings', which is above it in the tree.
After I figured out you have to actually hit the back button, I hit 'Change PC Settings' at the bottom. Network configuration is a PC setting, right?
I went through the ENTIRE thing and found NOTHING relating to network settings. In addition to that, when I accidentally hit 'HomeGroup' the thing softlocked for about 20-30 seconds; completely unresponsive save for a moving mouse and the spinning 'IM BUSY!' in place of the cursor.
Now Im HOT and feel like my head is going to pop; "You @#$@##^ worthless !@#!!, !@#@#, !@@!@$@"
One last thing to try; I hit WinKey and 'Desktop'
I bring up the right sidebar, which LOOKS EXACTLY THE SAME AS IT DID ON METRO.
Hit 'Settings', which LOOKS EXACTLY THE SAME AS IT DID ON METRO.
OH WAIT, IT does not!
Now it has 'Control Panel' at the top. FINALLY WE ARE GETTING SOMEWHERE!
From there Im easily able to get to the right area to fix the problem.
Why are there three places that it looks like I could fix the network problem from, but only one of them bears fruit? Its something I now know, so I learned how to get there. But why is it so difficult? Now that I think about it, I think I went through this before; Im having a serious case of deja vu, here.
Why take such effort to hide essential adjustment mechanisms? Why doesn't the 'Settings' menu under Metro have 'Control Panel' on it as well? It could simply pop you to Desktop and bring it up. What is 'PC Settings' for? It appears to have many things that were once a part of Control Panel in older variants of Windows. Except its broken off into this new fancy menu design and called something that makes me think I can fix the network settings. However, 'Network Settings' != 'PC Settings' Right.
My favorite Linux Distro is Gentoo. Im no stranger to difficulty. I dont know how much you know about Linux, but Gentoo is pretty DIY. Meaning, it does not have an installer. When you boot the install disc, it drops you to a shell and you have to install it pretty much manually by typing all the commands to partition, format, mount, download and untar the stage3, which is a stripped down Linux install, download and compile the kernel, install that and on and on and on.
It takes some work to install it, and maintain it, but I feel the pay off is worth it as the resulting machine is tailored for the programs and stuff that I want to run with no extra stuff that I dont use.
With Win8 Im like a dog chasing my tail, a lot of work for no pay off.
It feels like they were developing two versions of Win8, one for tablet and other for PC. At some point, later in the production cycle, someone decided to merge them together in this cobbled together mess. The 'PC Settings' is supposed to be the dumbed down menu on tablets. It has pretty much nothing that I care about in it.
So, pretty much, landfill material.
