Window shopping (literally)
Under the hood
Doing research for new windows and doors. Conditions call for fiberglass/composite, or aluminum clad wood; no vinyl. Not South Florida, but they will have to stand up to strong wind and sun exposure.
Hard to tell what actually stands up, and which companies back their warranties if needed.
Decisions based on brochures, salesmen, and in-store displays is probably not the best way to make decisions about something that will cost tens of thousands of dollars. Not unlike car shopping.
But there are no test drives, nor selling used; you're stuck with what you got, for better or worse.
So far, have gotten quotes specifying Marvin Ultimate line, to set a cost ceiling, if nothing else. And their patio doors do make positive impressions, relatively speaking, compared to even the TOL from other brands, like Andersen, with their odd protruding ledge on the sill. The hardware and latching mechanisms also offer clues about the level of design effort.
Marvin, Andersen, and Milgard seem to be what most shops are pushing. Visited a Pella showroom, but no knowledgeable salesmen present when I visited. Kolbe also seen in store.
Anyone else to consider? Jeld-Wen, Weather Shield?
Also need a side door for the garage. Fiberglass, half-light, pre-hung. A slab door would be nicer, but anything will be an upgrade to the original, and this is mostly about function, not looks.
Most specialty suppliers offer Therma-Tru and leave it at that. Big box stores have T-T, Masonite, MMI, and more, but the reviews about doors leaving the factory not square, warping, or not properly drilled do prompt pause. Not to mention shipping damage. Pretty sure the guy at the family-owned supplier will be around next year, while the guy who sells you the door at HD or Lowes may not be, and all that implies.
Welcome to any thoughts, or experiences.
Just installed this last Friday. Replaced a 32 year old steel/wood core for that rotted at the bottom due to a leaky gutter. Therma-Tru fiberglass. Fit was very tight. Put two coats of semigloss white on it, wife’s pleased and that’s all that matters. I want to
I’ll get an installed pic tomorrow.
Reminds me of a special buy HD had a few weeks ago. Supposedly an $1100 door. They had 2 for $380 so I snagged one. Composite frame. Fiberglass door shell with wood core.
We bought this house 10 years ago. The house is about 30 years old and has had some of its windows replaced.
Someone had replaced a large 2nd story window in a bathroom - an expensive window because of the large size and being right beside a tub had to be tempered glass. It started to leak between the panes and we got 2 quotes to replace it - $3600 and $1200 (yes a factor of 3 between the two estimates).
The window guy who had provided the low estimate also pointed out that it was a Milgard window and might still be under warranty. We didn't have bills or anything but contacted Milgard and by looking at the details stamped into the metal insert between the panes found out enough. Milgard recently replaced that window under warranty.
Thermoproof also replaced a number of the smaller leaking windows.
For both companies, I'd call that standing behind your product.
PS We're going to give our window guy $100 for pointing out that the window might be under warranty.
Pretty Happy with my double hung Milguard Tuscanys 5 years in. Warranty honored when I had 2 problems.
I'm deliriously happy with my Anlin Del Mars 3 years in. Warranty honored when I had 1 problem.
I'll never buy Anderson after watching my grandparents horrifically expensive casement windows never work.
I couldnt find a reason to spend more on Pellas than Anlins.
Marvin seems a great product.
The install will dictate a lot of your happiness.
Over the years I've been hearing good things about Jeld-Wen, but haven't looked into them much further.
My current home is ~70 years old and the old wood windows all look and perform close to what they did when installed in the mid 1950's (but only single pane from that era).
My Mom's house had Anderson wood windows. After 30 years the glass portion of these double pane windows started to sink or drop down a bit within their frame, like an 1/8" gap at the top so that outside air could pass right through. I brought it to the attention of the local Anderson dealer and since it was outside of the warranty period they had no interest at all - which I can understand. Nevertheless, I had to do something so I determined that their adhesive had failed. I rigged a set of clamps up with some good glue and gently got the glass back into position within the frames. It took a considerable amount of time because I had to move the glass slowly over a few days so not to crack it. I got it done but since this was only on about 5 of the 20 windows I'm pretty confident it was only a matter of time before others started showing the same symptoms. Mom passed about this time so the house was sold so don't know...
Anyway as a result of all of the above, I don't expect I will be using Anderson windows.
Good to hear all the way around. (y)
You said "not South Florida" but didn't relate your particular area. Perhaps the most important consideration here is whether you want (or require) impact-rated hurricane windows. You simply cannot compare standard windows as found in the Midwest to hurricane glass.
Any why not vinyl? Virtually every house here in South Texas uses vinyl windows, subject to high temps and plenty of winds. What's your reason for not wanting them?
A few years ago we had a complete set of Simonton StormBreaker vinyl windows installed. Excellent windows and a great value (averaged about a grand each, installed in 2023). Hurricane rated and a transferable lifetime warranty on the vinyl.
Very good luck with vinyl windows and fiberglass door for over twenty years now. What vinyl windows? Whatever ones Home Depot is selling. I have replaced all of the windows in two houses, an office and our church parish center building. For block walls, just cut the tabs off the windows on the shelf at Home Depot.
It sounds like you got a premium window that may work very well. My hesitation with vinyl (at least for now) is that after about 25 years the vinyl (i.e. plastic) will become brittle and start to crack or break up. That is indeed what is happening to my vinyl gutters now that I had installed on my home when I moved in 30 years ago. The gutters need to be replaced now for sure.
Maybe material science has advanced enough that the current formulations will hold up better, especially when exposed to sunlight. But that would be my concern with using the plastic's, that the industry calls vinyl as it sounds better.
I think that's the case with modern formulations. Simonton offers a transferable lifetime warranty on the vinyl. The original windows I had were non-impact rated aluminum. After many years of non-use by the original owner, they actually galled shut, with 8 out the 10 unable to open at all. And being the non-impact type, the frames had studs at each corner to install large pieces of plywood secured with wingnuts during any hurricane threats. It looks terrible and they aren't very energy efficient, either.
If one needs (or desires) impact-rated windows, I don't think there's a better deal to be had. The Pellas (and others) offered by the big-box stores cost about $5K more...and that was with a 10% military discount.
I don't know about the gutters, but I understand the concern. I had 6-inch one-piece aluminum gutters custom installed two years ago and didn't even consider the vinyl.
We are replacing all the windows in the house. We went with Andersen 400 series double hung, but we had to go with casement style for the kitchen/ bar area. The windows are small. I prefer double hung just because they are simple, but oh well.
I was buying them at a local building supply shop, but I recently learned Home Depot sells them as well. They had them 15% off and I was able to get the HD credit card and take advantage of their 24 month deferred interest promotion.
We're in the hills, so wind year round, compounded by sun and rain in the appropriate season. But no flying objects via hurricanes, so no impact rating required.
None of the half-dozen sellers I've talked to have recommended vinyl, given the conditions, and I don't believe that to be due to trying to upsell a more expensive line.
The existing windows are custom aluminum, and quite sturdy, but Al is no longer favored as a material due to energy efficiency requirements. Fleetwood still makes them, but they're pricey, and do meet the specs, but don't excel in that regard.
I also just prefer the greater heft and solidity of wood or if need be, fiberglass, which won't become brittle as quickly, and more readily accept paint if needed. As well as the better ability to cope with thermal expansion. The current windows are anodized, but faded, over a period of about 40 years, so they will hold up as well, albeit not infinitely. And a couple of them have lost glass seal integrity and clouded up, including one crappy patio door that was installed, very prematurely in its case.
To establish a cost ceiling, I chose to have Marvin Ultimate quoted for all the windows. Comes out to be around the average price of a new car in these times. Will have to consider if that works, but I do lean toward going TOL for the functional openings like the patio doors at least. I think it's worth it for those applications.
One question I forget to ask is the feeling about integrated internal blinds. Not considering them for the house windows, but for the garage door.
I like the feature in theory, but the skeptic in me sees the risk of something breaking, and the hassle of repair…if they can be repaired. Not to mention the added cost of such doors.
It's an older, narrower 30" opening, so the options are more limited, and frosted glass is not a factory option, but I can live with applying privacy film over standard clear windows. The garage door is solid wood, so the side door must function as the only source of natural light.
