Originally Posted By: Gary Allan
That's their advantage. A central air unit takes a long time to effect change from set point. A window unit does not. I an "open ended" max duty cycle, the window unit offers rapid cool down allow the unit to remain idle when that room or area is not in use.
I guess it comes down to what "change" one is after. There's heat, and there's humidity. There's BTUs, and there's pints per hour. There's cooling, and there's dehumidification. Any evaporator can only remove so much moisture from the air per hour. You can't quickly condition air in this regard. Window units are generally less efficient than central units at this. I don't live that far from you. Right about now, higher humidity is becoming a factor around here.
Most of the commercialized world lives in centrally conditioned spaces. It's there every time you walk into a store or office building or shopping mall. It does not feel as bitingly cold, but it doesn't have to, as it is usually much drier air than the typical overcooling window unit. IAQ folks will tell you that correctly conditioned air is both cool and DRY, and comfortable.
So why cranking a Haier to max output in a smaller space may bring the temps down in a hurry, it leaves a lot of humidity in the room. Humidity is half the comfort battle. When you do that, you HAVE to have it colder to reach a similar comfort index. More importantly, the oversized window unit NEVER lowers the humidity to the right "set point". That's their disadvantage. And the constant cycling is just plain uncomfortable.
This is NOT a statement against window units. I've used them for decades before getting lazy with central. It is just pointing out the disadvantages of using one with too much cooling capacity.
A properly sized window unit, with GOOD moisture removal rates (and that is the key spec that always gets ignored) can be the equal of central. A good Friedrich has solid dehumidification rates and can get pretty darn close to a Trane or Lennox, provided you give it some time.
It is a free country, which is why we are always free to disagree, hopefully with a smile.
