I just upgraded to Win XP Pro on my computer. It's a little older than today's PCs (P3 700Mhz, 256Mb, 160Gb HDD, circa 2000). I was previously running Win ME.
I have a HP Deskjet 5652 printer. It worked fine under ME (although I recall the installation was also troublesome without a reboot). However, I cannot get this printer to install under XP.
I run setup from the HP CD, and everything works ok, until it tries to detect the printer. The problem is, it's connected via a parallel printer cable, not USB cable. Why it is trying to plug and play a device not connected to a USB port is beyond me.
I can install the basic printer driver using the "add printers" menu, but in this case it does not install the HP software utilities needed to print (which give you options such as portrait/landscape layout, print quality, paper size, etc etc - which is sort of required). If I install the basic driver under the "add printers" method, I just get jumbled unreadable characters in the printer properties menu when attempting to print.
Does anyone have any ideas ? It would be greatly appreciated, as XP has been nothing but a headache so far
. I've searched the troubleshooting menu at HP's website, and they recommend a registry modification, which I'm not too keen or confident of doing, nor am I sure it will solve the problem.
http://h10025.www1.hp.com/ewfrf/wc/...&lang=en&lc=en&cc=au&dlc=en&docname=c00038749
![mad.gif](https://bobistheoilguy.com/forums/images/icons/mad.gif)
![rolleyes.gif](https://bobistheoilguy.com/forums/images/icons/rolleyes.gif)
