HP printer problems with Win 8
Near the beach in Delaware
I was helping someone with an HP 8600 wireless all-in-one printer. It worked wireless and USB several months ago. Then a storm knocked out the cell based wireless hub. After that was reset, USB works, but not wireless.
1) The printer itself shows connected to the proper wireless network with a valid IP address.
2) Laptop is also connected to same network, can browse the internet.
However I cannot use the wireless printer nor PING it. Nor try and browse the printers IP address.
I deleted all the printer stuff, downloaded new drivers, turned off firewall, still no good.
The HP install software cannot locate the printer either.
One odd thing, when I go to printer properties and the PORTS tab and click "configure" to look at the port setup, I get an error popup saying it cannot configure the port.
I am thinking there is something corrupted with the laptop.
Ideas short of reloading Win 8?
Originally Posted By: cmorr
Very odd that it's getting an an IP address (assume via DHCP on the router)but you cant PING it
I would download and run this utility:
http://h20180.www2.hp.com/apps/Nav?h_pag...g-NDU&ju...
Alternatively I would try to see if you can setup a static IP address on the router and assign it to the printers mac address. I do this on my home network, makes things much simpler/consistent
I tried that utility, did not solve anything.
The modem/router is a Verizon cell based hot spot. The person whom I was helping did not know the password. Its a limited function box that only allows a fixed number of connections (like 10) and not sure if it supports static IP addresses.
Have you checked your Windows 8 firewall settings or perhaps purchased a different anti-virus software for your new Window 8?
Maybe one of these is creating a conflict?
I doubt it's anything on the laptop side
Quoting the OP
"It worked wireless and USB several months ago. Then a storm knocked out the cell based wireless hub. After that was reset, USB works, but not wireless."
It's the hub (HW or SW config cleared)
Quoting the OP
At first I thought maybe each had connected to a different wireless router. But he says he only has one.
While people say "it worked fine until xyz happened" you never know.
Each gets connected to the wireless router and I can see in the printer display its connected and from the laptop I can get to the internet.
Getting an error under Win 8 when I try to configure the printer port lead me to think its the laptop.
I will bring another laptop when I go back.
I am thinking a Windows 8 "Refresh".
