Quote:
But it appears that none of the dino oils from the major players meet even ACEA A1. That is what prompted my original question. I find it interesting that, in all probability, API SM dinos don’t even meet the lowest standard of European (ACEA A1) oils.
I think any SM oil could likely pass A1 quite easily. SM and A1 are probably reasonably close in overall tests. A3/A5 does all the same tests as A1 but with a little lower NOACK (13% vs 15%) and a little tighter stay in grade. The A1 oils (conventional) in Europe are almost all Group I/I+ based or semi-synthetic Group I/synthetic. Our conventional Group II/II+ oils here in NA (North America) are superior to even the A3 synthetic-blends in Europe (when viewed from a base oil perspective). The NA oil producers here generally don't bother with any ACEA certifications (cost + not needed for the vast majority of vehicles sold here). They design the oils around SM and GF-4 and the fuel economy requirements of those sequences. The fuel economy requirements of SM/GF-4 (sequence VIB, 1.5% after 96 hours) probably means …
1) The oils have to shear to make that spec. This means they're probably not blended shear stable on purpose.
2) These oils have to be blended near the lower end of the viscosity spread (i.e. a 5W-30 will be ~ 10.7 cSt maximum, rather than up around 12.0 cSt.) If our SM 5W-30's were blended up around 12.0 cSt, or used more shear stable VII's they could meet even A3 with the Group II/II+'s. At 12.0 cSt they could shear down 2.0 cSt and still easily be in grade (A3 specification = stay in grade), but they wouldn't pass the fuel economy requirements of SM/GF-4.
Quote:
It’s a shame that the US market is way behind the times in this area.
I don't think we're behind -- in fact I think overall we're ahead here in NA. We only have one specification here in NA (SM) so the A3/A5 specifications are a little better than that one spec. But Europe failed to make any sizeable investment in Group II plants (some very small production), so even the mid-tier synthetic-blends in Europe are still majority Group I/I+ based. I'd much rather have a Group II/III blend than a Group I/III blend.
A Group I/I+ based synthetic-blend can even meet A3 in the heavier grades like 15W-40 or 10W-40. The base oils in these synthetic-blends (GI/III or GI/PAO) would have less than half the thermal/oxidative stability of the Group II/II+ base oils we use here in our off-the-shelf conventional SM oils here. So, when viewed from a conventional base oil perspective, and considering European mid-tier synthetic blends still use Group I base oils -- we're way ahead. Some of these Group I synthetic-blends are probably loaded up pretty good with additives to pass the spec's. Our Group II based conventional oils here are blended for a low cost solution to SM. If one puts a premium add pac in them they can perform very well. Agip even advertises their Group II's as performing like synthetics …
Quote:
AGIP…
Agip uses Group II base oils for its non-synthetic. … … Agip’s non-synthetics offer performance equivalent to most synthetics on the market.
Group II's could be blended to pass A1, A3 or A5, and they could do it easier and better than Group I/I+'s.
Since these GI blends can make A3, but they aren’t really that good oils, auto manufacturers have to make their own specifications to make sure the oils can cope with their oil drains. VW, MB, BMW, etc., all make their own specifications over and above ACEA because many of the ACEA spec'd oils aren’t really up to snuff. Do you want an A3 rated Group I based 15W-40 synthetic-blend, or a CI-4+ conventional 15W-40 GII? I'd take the NA GII oil hands down. The end result is that in Europe a good portion of the oils specified these days for many manufactures are synthetic. The use of synthetics as a percentage of the oil market is also much higher compared to here in NA (I
think probably approaching in the 30% range or more in some countries like Germany compared to 5-6% in NA).
They have a wide selection of very good synthetics in Europe, but they are expensive. If we were still using Group I oils in our conventionals, I probably wouldn't be using them -- I would likely switch to some Group III synthetic.
