Will Champion or NGK spark plug work better than generic Chinese?
I recently did a fuel system refresh on my old chainsaw, using a Hipa kit from Amazon. The spark plug that came with the kit is a no-name generic (I assume Chinese) plug. The OEM spark plug was a Champion CJ7Y which X-Refs to an NGK 6761. The saw runs fine with the generic plug, but would either of these plugs likely perform any better than the no-name generic plug from the Hipa kit?
Hands down dump the Chinese plug. I bought a poulan years ago as my first new gas trimmer. The Chinese plug was one of the reasons it ran so poorly. Night and day difference. I ran an NGK fine wire and currently an E3 plug in my Stihl.
If you want to try a platinum plug Napa sells an extreme plug that looks like a good long life bet.
I've never had anything but trouble with the cheap Chinese plugs, especially the Torch ones. Had a little Chinese scooter at one point, it ran for all of 5 minutes and then shut down. Went down the list of things and finally got to the spark plug, replaced with with an NGK from the auto parts store, fired right up again and ran like a champ after that. If it is running fine now, great, but I'd have a back up plug just in case.
Go back to the Champion, keep the Chinese one as a spare. If you foul the first one you might be able to warm the saw up on the second one then switch back. OPE plugs don't generally get "used up", they foul frequently but that can be cleaned with sandpaper or a blow torch. You can tell because the electrode and ground prong will still be "sharp" after typical dozens of hours of use.
I've found pretty much everything except older polaris snowmobiles to run better with an NGK plug, for some reason the old sleds like the champions
I'm going to test out the new NGK plug this weekend, along with taking the muffler apart and cleaning the spark arrestor screen if it's nasty.
This evening, I removed the plug that came with the Hipa kit and installed the new NGK plug. It may just be my imagination, but the saw seems to just run "better" with the NGK than it did with the plug from the Hipa kit. I incorrectly thought the plug in the Hipa kit was unmarked, but as it turns out, it was a "SAP L7TC" whatever that equates to. Into the trash can it went.
