Originally Posted By: Jake777
its leaking from around the Rear Main just a bit and also the oil pump area below the timing cover. its about 1-2 drops per night from what I can tell. I have been using PHM for the past 3 months and it did slow it down from where it was. I have a overstock of Maxlife 5w30 I was planning on using this next change in a week or so. The repair is expensive so I just put a bit of cardboard down in the garage where its parked for now.
I had a similar issue in our 2003 Corolla, so I went straight from QSGB to ML and the leak slowed within a few hundred miles. Now it's completely gone and I also have since switched to Mobil HM 5W20. The leak has not come back since I first switched to HM.
If it's an expensive fix, I would keep a close eye on the leak and monitor the oil level. Switch over to ML when it's time, and see how it works. If no change, then you might have to fix the leak itself. High mileage oils are great for conditioning the seals before they start to deteriorate and leak. When they are leaking already, it's hit-and-miss.
