I just replaced the old 10W30 synthetic in my B&S 3.75HP (Model 10D900) powered Sears pressure washer and now it appears to be overheating. As you know pressure washers run their engines hard (maybe 100% power output, I don’t know) and I am wondering if the 15W40 I just put in might be causing the problem. I would be surprised if it was, but this oil is thicker and will make the poor little engine work even harder. Until now I have not a lick of problem with this engine.
So, here is what happened. Yesterday I got the pressure washer out and fired it up like normal, happy in the thought that I had fresh Delvac 1300 in the sump. Outdoor temperatures were 90F+.
After maybe 10 minutes of nonstop washing I noticed the RPM’s were beginning to drop. I let off on the washing and the engine, now unloaded, ran fine. Went back to washing and after a minute or two the RPMS started dropping again.
This cycle went on a few times until the engine just died. At this point the engine felt really hot, water would boil when put on the lower half of the crankcase. But the engine started up again after giving the priming bulb a few pushes and the starter rope a few tugs. Maybe Vapor Lock?
My first thought was fuel starvation, so I will pull the carburetor and check the drop tube screen for blockage. The air filter is clean and I haven’t yet pulled the sparkplug to take a look at it. I'm using my usual gasoline with StaBil in it.
But the boiling hot engine has me concerned about the oil. Maybe I should go back to 5W30 synthetic. What do you think?
