Originally Posted By: Max_Wander
Originally Posted By: Onmo'Eegusee
WalMart policy is not to check brake fluid or coolant.
Seriously?? You may be sarcastic, but I would readily believe that!
when i went to tech school we were always told to never top off master cylinders. the only time we were to add fluid was when doing a flush after a pad swap or after replacing a hydraulic component.
Wows, who woulda thought eh. Maybe they don't want to mask what could potentially be a leak in the system?? can't think of any other reason for that policy
Pretty much I suspect. The only reason it should go low is brakes pads themselves are getting low. You don't want any leaks in something so crtical.
