Mobil 1 0W-40 Value
Viscosity, cSt (ASTM D445)
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
MRV at -40ºC, cP (ASTM D4684) 31,000
HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, ºC (ASTM D92) 230
Density @15.6 ºC, g/ml (ASTM D4052) 0.85
Mobil 1 5W-30
SAE Grade 5W-30
Viscosity @ 100ºC, cSt (ASTM D445) 11.0
Viscosity, @ 40ºC, cSt (ASTM D445) 61.7
Viscosity Index 172
Sulfated Ash, wt% (ASTM D874) 0.8
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.1
Pour Point, ºC (ASTM D97) -42
Density @15.6 ºC, mg/l (ASTM D4052) 0.855
Mobil 1 10W-30
SAE Grade 10W-30
Viscosity @ 100ºC, cSt (ASTM D445) 10.1
Viscosity, @ 40ºC, cSt (ASTM D445) 63.2
Viscosity Index 146
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.0
Flash Point, ºC (ASTM D92) 232
Density @15.6 ºC, g/ml (ASTM D 4052) 0.859
M1 0w-40 actually seems thicker at 40c than 5w-30.
"Weigh"ing both is a little difficult becuase 0w also has a great HTHS. The thinner 5w should offer a little more startup protection but the benefits of the 0w-40 package make it difficult to disregard. It also brands the long life usage from BMW. But it does not carry any GM approval.
Why does GM approve so much more the 5w-30? it would seem like the 0w-40 formula offers more protection and also has more zddp.
I dont think i can mix the 2 becuz the oil pan pick up on a chevy small block is so low in the pan..it would only pickup the heavier of the two at startup so if i wanted to stay with Mobil 1 I would have to choose 1 or the other.
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
Mobil 1 5W-30
SAE Grade 5W-30
Viscosity Index 172
Mobil 1 10W-30
SAE Grade 10W-30
Viscosity Index 146
