It only happens when the ambiance temperature is low (lets say under 10 degrees celsius).
It's a diesel 320d.
It doesn't throw up visible steam, it only creates that wet spot on the ground. But when I put a cardboard it doesn't get wet at all! The same occurs when I put a piece of cloth, or a mirror... they just don't get wet.
I'm kinda confused right now, bc I think it could be headgasket or EGR cooler leak to the admision... but the car doesn't burn oil and the coolant level is OK (I don't have to refill).
So what's the issue here? Car works perfectly fine, It doesn't overheat
It's a diesel 320d.
