Several months ago, I installed some LED driving lights on my 2017 Camaro, because while the headlights do a great job of FORWARD illimination, the projector beams do little for side illimination (like none). Surprisingly, Tractor Supply had a really good set of LEDs (of course the lights, 'Y' connector and wiring harness were separate), but they dramatically improved the 'side of the road' illumination.
One "drawback" was that the wiring kit had (for my application), way too much wire length (like 12 feet worth), but it was too cold and too cramped under the front of the car, so I just tucked all the excess behind the bumper cover, thinking it was safe enough and planned to "fix" it at a later time. That 'later time' turned out to be yesterday, after I discovered the lights, which I wired to come on with my parking lights, started flickering.
I had connected the wire to activate the relay to the side marker light, and initially thought that the connection was failing. So I took the easy route this time. Jacked the R/F corner up, removed the tire & fender liner. That way I could easily access the extra wiring and inspect the possibly faulty connection. I could easily see the connection (even through the 'coil of snakes' that was all the tucked-away wiring, it looked OK. I decided that since I was under there anyway, I would cut and splice the wire to make things neater. So as I pulled out the mess, I immediately saw an issue. The relay, especially the connection that goes straight to the battery was LOADED with corrosion - all green and gray looking. I immediately knew what my issue was.
I pulled the relay (after breaking loose the corrosion cement and initially thought that it was a 3-pin connection. Turns out, the battery terminal was so bad, that the pin had almost totally rotted away. After about 10 minutes of trying to clean and save the relay/harness, I made a trip to Summit Racing for a new harness and relay. Fast forward about an hour or so, and with 12 feet of exccess wiring laying on the floor, the new harness installed and the relay installed to the radiator support (a much better, more protected area), my lights were working flawlessly again. It was kind of cool, chilling in the garage - cup(s) of coffee at hand, with music playing from my phone and just tinkering with the car.
Anyhow, here's what the old relay/harness looed like - remember - this is AFTER being cleaned!
