bulb pin out h-4 and 9004
indianapolis in
[size:17pt]Does anyone have the pin out for both H-4 and 9004 bulbs? I am finally replacing the worthless aero 9004 headlights with Hella 165mm Euro lights that use H-4 bulbs in a 1994 Dodge Dakota standard cab. The OEM wiring harness goes up to the front and there are two 9"? stub pigtails that end in either the sealed beam (but not the normal sealed beam prongs ) or the 9004 bulb. It is a big deal to change lights, contrary to my expectation. I suspect and hope the 165mm Hella Low/Hi will be a big improvement, and it will be easy to install a HID or LED KIT and see what that results in. Next project is a relay kit, as I assume Chrysler does not provide relays standard on the headlight switch, and a truck with no headlights is a real drawback at night.Thanks!
