- Joined
- Jun 2, 2003
- Messages
- 23,587
Due to a lack of time this project will take me a few weekends. I will update this thread whenever there is progress.
The goal:
1. Add three relays for low beams, high beams and fog lights to the headlamp/lightswitch circuit.
2. Upgrade the wiring to larger gauge.
3. The added wiring harness must be reversible simply by unplugging it in order to restore wiring to OEM.
4. If reasonably doable, tap into alternator, alternatively, tap into battery.
5. Philips X-Treme H7 bulbs are on the way
The first step is upgrading the the wiring inside the headlamp housings. The first photo shows the lamp housing with the the original wiring, which is relatively skimpy:
A closer look at the original wiring harness from inside the headlamp housing. The pins have been removed from the OEM connector:
This picture shows the OEM pins, which I reused. Note the skimpy OEM wires, which were upgraded:
This picture shows the original harness on the side, while the upgraded harness has been installed:
The new, larger gauge wire was soldered to the pins, shrink tubing/shrink tape was applied, and the pins were inserted into the connector:
I installed the new wiring only in the driver side headlamp housing, and although I have not yet upgraded any other wiring, the left lamps are already considerably brighter, which I find amazing!
The next step will be to repeat this whole procedure on the passenger side headlamp.
Then I will install the already prepared harness that will got to the relays. I have found a good location for the relays. It appears that there is enough space inside my ECU box (under the hood) for the relays. I am hoping the relays' magnetic field will not disturb the ECU, which is shielded.
To be continued....
The goal:
To be continued....
