Headlight Relay upgrade.
Central Washington
When I first bought my car I noticed the headlights were...sucky. The first thing I did was install XtraVisions, which helped a little. But then I noticed on one of the crown vic forums that a member was making a harness specifically for this platform, with all the wiring laid out to make install easy. I found out that he stopped making them and hes selling the leftovers so I bought one real quick..
The difference is incredible. I don't have any before and after pictures to show, but I was impressed. I drive a lot on unlit rural roads, and I no longer have to use high beams to see street signs. I can see a reflection before I can actually read them. (This makes me wonder if they are aimed too high now, though). Actual high beams are almost useless, they throw a bit more light directly out front and the sides but thats it.
Okay, here are some pictures of the harness.
Click the pictures in the album to full size them.
Stock wiring to new wiring comparison.
Rest of the wiring and relays.
I upgraded both my jeep and dodge neon with harnesses that I made. It's pretty easy with some planning. Here is my schematic.
I did the same thing in my Jeep too. I was getting about 11 volts at the headlights before, and a full 14 volts when I was finished. It only cost me about $10, for the relays, the rest was made from cut up extension cords.
From Daniel Stern's web site
http://www.danielsternlighting.com/tech/relays/relays.htmlRelays:
WHY AND HOW TO UPGRADE YOUR HEADLAMP CIRCUIT
By Daniel Stern with special assistance from Steve Lacker
Click here for a printer-friendly PDF version of this article.
THOUGHTFUL CARE & CAREFUL THOUGHT REQUIRED
The success or failure of your lighting upgrade efforts rides on the quality of your parts and the quality of your work. It matters how carefully you route wires to avoid chafing insulation. It matters how well you solder connections (crimps and sloppy or 'cold' solder joints corrode and die). It matters how well you shield added wiring from road spray. It matters that you use fuses in the new wiring to protect against vehicle damage due to a new or old electrical fault. It matters that you use high-quality parts that are designed to stand up to the rigors of automotive usage. Such components must be resistant to a wide range of temperatures, road splash, fumes found under the hood of every car, severe and prolonged vibration, etc. It will pay you to select only the products of companies with well established reputations for quality and durability; your $2.25 bargain no-name relay could easily kill you when it fails on a dark road somewhere, leaving you with no lights. Do not purchase vehicle components based solely on price!
The techniques described in this article will yield excellent results only if the work is carried out carefully and to a high standard, with quality parts and materials and without corner-cutting or sloppy work.
I personally wouldn't perform this upgrade on a really collectible car without taking care to hide all the new wiring. Actually, there's probably not much need to go to high-powered Cibie (or other European-specification) headlamps on a true collector car that is not driven at night. But on a hard-working daily (and nightly) driver like mine, powerful headlights are a real blessing, and keeping the wiring out in the open where it can be seen and inspected helps avoid failures!! Also keep in mind that this article focusses on the general principle behind headlamp wiring. There are many variations in original-equipment headlamp circuit design, and it will be worth your while to examine your vehicle's setup thoroughly, preferably with the aid of wiring diagrams applicable to your specific vehicle.
WHY USE RELAYS?
Power for the headlights is controlled by a switch on the dash. This is *not* a great place to tap into the system, for two reasons: The headlamp switch uses tiny, high-resistance contacts to complete circuits, and the wire lengths required to run from the battery to the dashboard and all the way out to the headlamps creates excessive resistive voltage drop, especially with the thin wires used in most factory installations.
In many cases, the thin factory wires are inadequate even for the stock headlamp equipment. Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages:
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens ←Rated output voltage
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens ←Rated life voltage
14.5V : 1528 lumens
The Europeans take a slightly more realistic with their voltage ratings; they consider output at 13.2v to be "100%". The loss curve is the same, though. When operating voltage drops to 95 percent (12.54v), headlamp bulbs produce only 83 percent of their rated light output. When voltage drops to 90 percent (11.88v), bulb output is only 67 percent of what it should be. And when voltage drops to 85 percent (11.22v), bulb output is a paltry 53 percent of normal! It is much more common than you might think for factory headlamp wiring/switch setups to produce this kind of voltage drop, especially once they're no longer brand new and the connections have accumulated some corrosion and dirt.
WHY USE RELAYS?
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
13.0V : 1054 lumens
13.5V : 1198 lumens
14.5V : 1528 lumens
Also look at
http://www.vintagewatercooleds.com/tech/Techtips/Timbotechnotes/headlight/Headlight.htm
As did I.
I had an 89' Volvo 240 and I decided I wasn't going to screw around with sucky plastic headlights and inferior 9004 bulbs. So I bought eCodes, and when I did that I did a relay kit.
The other advantage of doing this was I just hooked the wiring up to the switching box for the highbeams on the front left fender (not the proper term, sorry) and then a wire run up to the switch inside the car, and then just ran right off my battery directly. Suddenly my car was running both connections, meaning when I went back to stock to sell the car, it was MUCH easier since nothing had been cut. I had my H4 bulbs connected to my relay kit, and I had the 9004 connections still intact, just sitting there.
From this;
to this;
In about 15 minutes, most of that time being pulling out the relay kit and the associated wiring.
Anyways, I most definitely would do it again on any car, night and day difference.
Toyotas and maybe other brands that switch the negative side of the headlight circuit require a specially made harness. Some of the Toyotas have problems with dash lighting with after market harnesses. I bought a Toyota harness from Susquehanna MotorSports a couple of years ago, it didn't work on my Tundra, and I redesigned it by removing unneeded parts to solve the dash light problem I didn't have. (Toyotas have the positive wire always connected to the headlights and switch the negative side. Is this more reliable than switching the positive and connecting the negative to ground?)
