Originally Posted By: SoNic67
Your post tried to discredit what I just said above by going out of way and...
No, all I was trying to point out was that this was not always the case, and I have provided examples of that. You've chosen to get offended by that for some reason.
I showed your error in this 'scientific' investigation. You never change multiple variables in an experiment/argument, unless you are trying to pull a
straw-man . Oh wait, isn't
that a personal attack?
Well, last I checked, your "absolute" statement that I took issue with didn't have any sort of experiment associated with it and certainly wasn't any form of scientific paper. It wasn't even an argument, it was a statement. When I mentioned that it wasn't always the case, you further clarified. When I cited an example that fell within the terms of your clarification, you again took exception and then started on with this tripe about changing multiple variables, whilst that was not one of the qualifiers in your original statement, nor your second one.
If your original statement had read something like what I stated in my last post, that GENERALLY, the wider the visc spread, the higher the NOACK volatility, I would not have taken exception, as that is correct. There are exceptions, but it is a good GENERAL rule of thumb. And there are exceptions, as I already noted, even if we use your qualifiers of same brand and type (part 2 of your clarification) and the same grade (part 3).
After all that you came back with a post that actually support my original point (that there are advantages of 5W versus 0W exactly because of NOACK)...
Because it is
GENERALLY correct. My point wasn't that you were completely wrong, simply that this was not always the case, and I've said as much several times now.
And you still haven't provided any further clarification on your 200,000 mile 20 grade statement BTW.
I guess you like to argue???
This isn't really an argument, this is you getting offended by somebody taking exception to what you've said, getting angry and tossing in qualifiers that weren't part of your original statement, nor your 2nd statement, when questions were asked/statements made regarding that content.
I DO enjoy a good civil debate, but this has not been one of those because instead of allowing that to happen and asking your own questions, you got huffy and started tossing out insults. That's not protocol conducive to discourse that would qualify as debate.
