Originally Posted By: XS650
My point was that they operate at about 9 times the frequecy stated earlier.
Are you sure about lower power for lower frequency? Higher frequency crystals have less mass so could take less current to excite. Whether that is offset by other things, I don't know.
I gave andyd the benefit of the doubt when I figured he had forgotten the k of khz...
Power consumption is linked to the size of the tuning fork resonator quartz. Quartz size is linked to frequency (Due to manufacturing limits? I don't know). Modern quartz watched contain very small crystals, about 4 mm long. I have an early 1970's LED quartz watch, and even if I don't use it (don't light up the display), it drains a set of button cells in 2 months. The quartz resonator in that puppy is over 1 cm long, over 4 mm high, and 3 mm wide! Compared to that, a typical quarts resonator in a modern quartz watch is less that 1/5th the size.
