There are so many factors that can lead to oil consumption. Some designs are more prone than others. The Cadillac Northstar 4.6 V-8 was a common oil burner, and Cadillac service at one time considered a quart every 1000 miles to be the upper limit of consumption allowed, beyond which they would perform a ring and intake cleaning procedure on the engine under warranty. Mine burned about a quart every 1500-2000 miles, and a GM powerplant engineer told me that the reason was the cylinder bore and the aggressive hash pattern that was deliberately ground into the cylinders in order to "hold" oil in the upper parts of the cylinder to keep the rings well lubricated. If the rings got sticky, they would tend to hold even more oil and it burned a lot. One of the recommendations that engineer gave me was the old "Italian Tune-up," whereby you drop the trans into 2nd or 3rd, accelerate with wide-open throttle to the top of 3rd gear (before the trans auto-shifted into 4th to prevent blowing up the engine), then coast it down with closed throttle to about 20-30 MPH. Repeat 4 or 5 times to help blow out the rings on WOT and then pull them under high vacuum as you decelerate from high RPMs. That procedure never changed my consumption, but I have definitely seen Northstars blow black smoke out the tailpipe under WOT before and heard stories about that process reducing oil consumption for others.
So cylinder bore honing patterns affect it, as do ring type, number, and positions, piston shapes, oil fill levels, driving styles, turbo/non-turbo, compression ratios, gas/diesel, oil composition, manufacturing differences... Lots of factors to consider. I don't think oil consumption is a big problem unless the PCV system is getting clogged, the intake valves or rings are getting crudded up, or the catalytic converters are getting poisoned. Northstars run for lots of miles with no problems at all from the oil consumption. Other cars might have stuck ring issues or burn through converters. I do not believe that poor maintenance is usually to blame for oil consumption. There are just too many other factors that can cause it, though lousy maintenance on a car prone to consumption might be a recipe for problems. I haven't heard many stories of Chevy 350's burning oil unless there was some other problem causing it. Your oil choice probably has little to do with it.
