- Joined
- Jun 2, 2003
- Messages
- 23,591
Yes, G-Man-II, I mixed up A2 with A5. Stupid number salad.quote:
A2 is the ACEA spec for std, non-synthetic motor oil and is basically dormant. It hasn't been updated by the ACEA since 1996. A1 and A5 are the low HT/HS specs, with A5 also being an extended drain spec.
dustyjoe1, the claim that Euro engines have looser clearances (not tolerances!) has been brought up many times before, but never confirmed. In fact, someone who built race car engines to me the bearing clearances in my '96 Audi were pretty much the same as those in a '70s Nissan. The traditiona trend to slightly thicker oils in Euro engines is based on driving conditions. But as I said, check the oil recommendations of new Euro cars in Europe, and you will see more recommndations for thinner oils than a few years ago. If you talk to European drivers, you will also find that many prefer to not go for the extra-long extened drain intervals of up to 30k km or more, but that many stick with thicker (usually A3 rated) oil and normal drain intervals of 10 - 15 km. I know this from what I read on German automotive forums and the people I've talked to.
There is nothing to the suspicion that carmakers build their engines with different clearancs for different markets. If my motor can, according to the manual, use oil weights from 5W-30 to 10W-60/20W-50, then I would have to assume that my engine has variable clearances. This is of course not the case, and the viscosity recommendation depends on temperature and type of oil. 5W-40 happens to be the best compromise for my motor, no matter if the car is driven in the US or in Europe for all year-round use.
Also, my '96 Audi manual points out in the US manual that oil requirements in Europe differ from the ones in the US due to highway speed. Audi clearly states that oil choice (in regard to approved specs) is more critical when dribving in Europe. I posted a scan of this part of my manual on this site before.
[ May 16, 2004, 03:55 PM: Message edited by: moribundman ]
