Originally Posted By: BigCahuna
So after reading all the posts it must mean excessive idling is the best possible way to operate your motor. At idle the motor is running at low speed just enough to circulate the oil. It's given just enough fuel to keep it running, so no dilution. Internal parts are hardly making contact, just barely moving. And you get the best mileage per gallon. But some will say it's also severe service.,,,
Here is an idea.
1) Change oil in your car and save a small sample of new oil.
2) Start the car with new oil and full tank of gas.
3) Let it idle until it runs out of gas.
4) Now take a sample of the oil that has ZERO miles on it, but about 30 hours of idling (assuming 15 gallon tank and 1/2 gallon per hour fuel consumption.)
5) Send both samples for a UOA and then come back and post the results.
I bet the results will speak for themselves as far as metals and fuel dilution numbers, and you will never again say that idling is not severe service.
Here is an idea.
