This was fixed in other/newer versions, it was just the LLT I believe that suffered from this, they went from 3 timing chains to 2 in the later revisions and as far as I know those don't have the same issues.Idk… I do like having 300HP V6’s though.
Less noise.
Yep....Pontiac V8 engines of the 60's and 70's had nylon covered gears, were known for timing chains.....also 1st gen EcoTec 4 cylinders.....tensioners shot crap, and chains did shortly thereafter.I prefer chains over belts but it comes with a HUGE qualifier. Quality chains! IIRC there was a series of GM engines that had issues with chains. Issues traced back to inferior quality chains used. I'm sure GM was not the only one but it is the manufacturer I remember.
Its true, I know a lot of Germans that insist on using cheap oil, they cannot be convinced that synthetic is so much better and cheaper in the long run.Thats my expirence with other people.. with car owners here in germany. 90% of them prefer the chepaest oil and do the longest possible OCIs.
if you dont like what i am posting or dont belive it, thats O.K.
*shrug*
One key difference: chains are covered under warranty esp. extended warranties where belts are generally a maintenance/wear item.
The Ford 3.5/3.7 also has issues, not specifically with the chain itself but the water pump that is driven off it, and has no external weephole, so when the water pump leaks/fails it floods your sump with coolant and destroys the bearings. A shame since those are otherwise excellent engines.I certainly prefer a chain if its a good setup, many are not, Nissan 3.5, Ford tritons, Ford Ecoboost, 3.6 Gms, the Ford 4.0 Sohc with the jackshaft that runs to the back of the engine and has a failure prone chain guides sitting on the back of the engine. Oh there are so many problematic timing chain setups its hard to remember them all. Many good ones as well.
I meant the “is DOHC in a V really worth it? I think not” part, I’m all for them, I loved my Pentastar.This was fixed in other/newer versions, it was just the LLT I believe that suffered from this, they went from 3 timing chains to 2 in the later revisions and as far as I know those don't have the same issues.
I'm constantly hearing about timing chain replacement. Not to mention the tensioners, and guides that go along with them. That always seem to get chewed up. I had a belt driven camshaft on my 1979 VW Diesel. It had 137,000 miles on it when I sold it, and it was never touched. And if it ever needed replacement, it was a snap.
Simply remove the sheet metal cover, insert 2 dowel pins to lock the cam and crank in position. Then apply some pressure with a breaker bar against the tensioner, and slip off the old one, and install the new one. It was as, if not easier than replacing a Serpentine Belt that most all cars have today that drive everything.
This image is like a find waldo puzzle using timing chains. I am confused. Just how many chains are there? I can see three, but I can't trace the loop of the one driven by the crankshaft. This thing is a labyrinth.Audi V8 Chain setup. German over-engineering destined to fail. Kids with CAD = bad engineering more often than not.
A Dodge Charger with a 6'er was one going ride I rented in Florida a few years ago.I meant the “is DOHC in a V really worth it? I think not” part, I’m all for them, I loved my Pentastar.
Here is the Pentastar; Much like two inline 3's joined at the hip with an oil pump and orI meant the “is DOHC in a V really worth it? I think not” part, I’m all for them, I loved my Pentastar.
How about a 300HP I-5?Idk… I do like having 300HP V6’s though.
Pilot timing belt is a 2 hr job for most techs, maybe less. But dealer price for the timing belt pkg, plugs and valve adjust total about $2500 around here, so it isn't much less than the timing chain job.I used to hate the idea of timing belts. Then I owned a Chevy Traverse, with the 3.6 that was known to have timing chain issues. To be fair, it made it to 170,000 before the dreaded cam position error codes came up, but I couldn't justify the $3000+ to drop the whole front end to get the engine out to replace all 3 timing chains and the sprockets. Obviously way beyond home repair. The timing belt in my Pilot doesn't seem so bad after all, at least that's within my ability, and it can be done with the engine in the car.
