You have me confused.I don't get it. Chains are far superior, yet Honda keeps using chains...makes no sense...
I believe only V6 uses a belt. Dry at that.Are the newer Honda's using belts? Are these belts oil lubricated? This is a confusing thread.
I prefer the no maintenance associated with a chain.
My Corolla has 423K miles on the original chain...tell me how belts are better...I am on the opposite camp since I prefer timing belts. The chains do have there problems with quides and chain stretch!
I could see doing on a non-interference engine, but the Honda engines ARE interference engines...if the belt goes, so does the engine...like I said, my Corolla is still on the original chain at 423K miles...let's see a belt do that...I've never heard of belts having problems, I've heard of people going 20 years and 250k miles on OE Toyota belts, not that I recommend that, but how many cars out there with timing chains have problems with eating guides or failing tensioners or other problems, other than it being kind of a nuisance timing belts are generally more reliable than chain systems, result in less parasitic loss, and are quieter.
My with a 2.4 had 386000 on it no issues..My Corolla has 423K miles on the original chain...tell me how belts are better...
Because in the vast majority of cases chains never need to be replaced. Belts always do. It's not rocket science...I'd be interested in hearing why people think roller chains are supposedly superior? How is driving a camshaft different than driving the rear wheel on a motorcycle? Harley went to slotted drive belts back in the 80's, and never looked back. They're smoother, quieter, don't stretch as bad, and have no need for lubrication. And many would argue they are actually stronger.
If they wanted a truly superior system, they would have to go to a completely gear driven drive system, like Formula 1 engines do. But that would be prohibitively expensive.
I'd prefer a belt if they made them easy to get to, but the problem is in a lot of FWD cars servicing a belt becomes about as much of an undertaking as servicing a chain, now on the other hand if my 4.2L Straight 6 in my Trailblazer had a belt, they probably would've made the oil pan shorter, they wouldn't have put some of the timing cover bolts where the oil pan has to be removed to remove them and you'd probably be able to change the belt in the car pretty easy after removing the accessory drive. Now in practice my mom's 2008 Odyssey with a J series Honda motor you have to take apart most of the engine bay to get to the serpentine belt to remove the accessory drive to even be able to get into the timing cover.I have always preferred chains. But now with DI, and the associated soot, and fuel dilution, I wonder if belts might be a better option for DI engines.
I don't know, but it's worth discussion.
