No! If you continue down this path for another 120 credit hours you will receive your MS or More S#IT degree. Go for it!!!Double major, but still BS.
That graph you call the "3 factor bearing graph" is actually called the "Stribeck Curve", and pertains to the lubrication regimes that exists between any two moving parts, not just journal bearings (Google it). Journal bearings behave per and are designed by the Sommerfeld equation, that's where the "bearing charactor number" comes from … it's the Sommerfeld number (Google that too).![]()
The Y axis represents friction. The X axis represents N x v/L which is the "Bearing characteristic number" The transition is > .0000017.
v= viscosity N= rpm L= Load
Numbers under .0000017 are unstable and lead to mixed and thin film lubrication. With lower viscosity there is less cushion when loads increase like when shifting or hard acceleration. To me its just common sense.
What's the definition of "fine"? Not taken back home on a trailer, lol. Guy on YT who tracked his car on the oil cap 5W-20 inspected his rod bearings after a few heavy track sessions and wondered why his journal bearings had so much wear. He thought it was a good idea to run the 5W-20 because he wanted cooler oil temps.Getting ready to head to VIR this weekend for a 2-day HPDE. A buddy tracks his GR Supra and I just found out he runs the factory recommended 0W20 and will be there...he has several track days on it so far....my prediction? Will be fine...
Even so thats not the way comparative quality analysis is accomplished between oils. The proper ASTM test doesn’t use a simple and uncontrolled spectrographic analysis.There's a ton of multi run analysis threads and even ones comparing 30 and 20 in the same engine.
Here's two I found in 1 minute:
This has been the highest interval between oil changes with this car and the UOA still is pretty uneventful, except for the slight uptick in Fe.
Replaced with 5W30 Euro L once more, which is likely to be the final use of Euro L, only because I've run out. I use either PP or PUP 5W20 in my other 2 vehicles so the Civic will likely start on a diet of the same. I'm going to target 8 or 9K for the next interval... not ready to go 11K as suggested.
Car also got:
- new wipers, only 2nd time changing since new,
- battery, replaced free under 4yr warranty, Duralast Platinum (35 months ago)
- chinee
- Forum: Used Oil Analysis - Gasoline
A lot of data here. Not a perfect comparison Regular Edge 5w20 vs Edge EP 5w30 and that EP saw a chunk of winter driving but here’s how the two looked in my Mustang over semi-long intervals.
Executive summary
Edge EP 5w30 @ 8200 miles
Time: March 2024 - February 2025
Fe+Al+Cu = 10 / 8.2 ~ 1.2 ppm/1k
Oxidation: 12
Boron: 37 ppm
KV100: 10.2 cSt
Edge 5W20 @ 8693 miles
Time: March 2023 - October 2023
Fe+Al+Cu = 17 - 6 @ 228 miles / 8.465 ~ 1.3 ppm/1k
Oxidation: 15, 8 VOA
Boron: 33 ppm, 151 ppm VOA
KV100: 8.5 cSt, 8.3 cSt VOA
The 5w20 run started with Blackstone but I switched to Oil...
- RevvCats
Lubrication is just one of the 5 functions of motor oil, - the main one - that gets all the attention.Those are great engines, my daughter’s 2016 RDX has one. I use 0w30 and it’s never burned a drop of oil, knock on wood.
Sorry I learned alll about this in engineering school. Its for sliding surfaces (including bearings ) as noted.That graph you call the "3 factor bearing graph" is actually called the "Stribeck Curve", and pertains to the lubrication regimes that exists between any two moving parts, not just journal bearings (Google it). Journal bearings behave per and are designed by the Sommerfeld equation, that's where the "bearing charactor number" comes from … it's the Sommerfeld number (Google that too).
This thick vs thin thread has some steam, but I'll say what I end up saying in most of these threads. If the cap says xW-20 or lower, go up a KV100 grade because MOFT headroom is a good thing. Helps keep those top rod bearings and cam chains healthy. Most likely why Ford finally woke up and went from 5W-20 to 5W-30 in the Coyote sold in the USA. It was always speced for 5W-30 in some other counties. Ford trashed CAFE for more engine protection, like it should be.![]()
Do you have a link to this?What's the definition of "fine"? Not taken back home on a trailer, lol. Guy on YT who tracked his car on the oil cap 5W-20 inspected his rod bearings after a few heavy track sessions and wondered why his journal bearings had so much wear. He thought it was a good idea to run the 5W-20 because he wanted cooler oil temps.![]()
Remember even at a low 1200 rpm speed, a four cylinder engine is firing each cylinder Ten times per second.You brought up a very good point. I was taught not to "lug" an engine, and I always downshift, even with an automatic trans, when going up a hill so the engine can run freely under a lighter load.
I've never examined bearings before, but your suggestion looks and sounds reasonable.
Why would anyone pull their engine part ot inspect rod bearings after a track day? What was the issue that presented itself afterwards that wasn't there before driving this? You've commented this many times - link for the video for my info? I'll be sure to talk to this guy and send him here for a proper thickie beatingWhat's the definition of "fine"? Not taken back home on a trailer, lol. Guy on YT who tracked his car on the oil cap 5W-20 inspected his rod bearings after a few heavy track sessions and wondered why his journal bearings had so much wear. He thought it was a good idea to run the 5W-20 because he wanted cooler oil temps.![]()
The GR Supra probably has a good oil cooler, but going up a grade would still add protection.
Are there times when no discernable wear is found? It seems that even with a well-lubricated, maintained, and operated engine, wear would always occur in that area.I guess I need to explain my post better. Sometimes when dissembling an engine for inspection you will find wear on the upper rod bearing halves(like shown below) and no wear at all on the bottom half. What causes this is during TDC of the power stroke energy travels down the connecting rod to the crank. This squeezes the oil “cushion” between the crank journal and upper rod bearing half. If oil temperatures get to hot and viscosity is to low this cushion could go to zero causing friction and wear. This is common during severe service like racing, towing, plowing etc. and one reason why some manufacturers recommended a higher viscosity in severe service. Something like oil starvation usually causes wear to upper and lower rod bearings.
There is always some wear, but it is not normal to wear through layers of a bearing. I’ve inspected many 200k+ mile engines with virtually no visible wear on the bearings. If I measured them I would find some wear. These bearings have allowable tolerances.Are there times when no discernable wear is found? It seems that even with a well-lubricated, maintained, and operated engine, wear would always occur in that area.
Two stroke oil/fuel ratios have more to do with rpm than load.In a two stroke outboard that uses pre mixed oil into the gas you run 50 parts gas to 1 part oil for everyday normal use. 50:1 Pulling skiers and running hard you use 40 parts oil. 40:1 If you ring it’s neck out because you are way under powered or racing high rpm you run 30 to 1 gas oil ratio. 30:1 On engines that internally mix in oil into the fuel line it may go as light as 100:1 if you are at idle or trolling slow. 100:1
In car engines you do the same except instead of increasing oil ratio you change viscosity. Example in my E350 4x4 adventure van pulling the race trailer I’m not running the recommended 5w20 pulling that load thru mountains so I step it up to 5w30 with an extra shot of molly. If you baby your engine with a light load then thin oil lubricates perfect and keeps things clean. If you frequently max it out or pull mountains then go up in viscosity. Pick your viscosity based on how hard you are asking that engine to work.
I bought a new XP 346 back in the day. It will make even the most experienced chainsaw operators put their saws down and say wow! Honestly one of the best performing fuel operated piece of machinery on earth. Maybe one of Elon‘s rockets would be ahead of it? I doubt it. Nothing does what is supposed to better than a Husqvarna HP.Two stroke oil/fuel ratios have more to do with rpm than load.
I have 3 Husqvarna XP chainsaws and a 35cc weed whacker that run over 10,000 rpm. Same goes for small two stroke dirt bikes, while an outboard boat motor might see 5,500 rpm.
A friend of mine tracks his Fit. Champcar endurance series. I'm sure they are using a 40 grade but I'll find out....It really depends on the engine and the conditions subjected to as to whether it would matter to go up a grade. An increase in headroom is a more sound argument since what harm is there anyway, as others have argued.
Let’s say my personal vehicle (Honda Fit L15A1 engine) with low oil temps and seemingly great UOAs (though not meant to determine absolute wear it’s an okay indication how the engine is treating the oil at least); I’ve never thought it was a need to go up a grade.
However, I did recently (at 320k) because it’s well over 300k miles (just passed 340k) and there is a slow rear main leak. It felt slightly more peppy since upping a grade. But, I also changed to running premium fuel (dealing with emissions passing in my area on an aftermarket CAT) 93 regularly instead of 87. And, I also had a spark plug back out recently, though I was already on 30 grade when that happened, so the oil grade may have nothing to do with it, but I say all of this to say my performance wasn’t worse being thicker one grade. I had other factors to engine running condition than oil grade. Maybe it likes the Amsoil Signature better rather than the grade of oil.
So, what is the harm?
160F peak oil temps
Port fuel injected
70% highway miles
Seldom short tripped
Not severe winters; nor track days…
In this case, the cap recommended 5w20 (before 0w20 was the standard) has likely been sufficient. Though a Honda I4 non-turbo going past 300k miles isn’t remarkable. So, part of me does wonder if I had gone up a grade with long term ownership would I have a slightly less worn engine today? That’s possible though likely not a factor for my engine given the above factors.
A thicker oil grade is recommended in other parts of the world for the same engine. It does lead one to wonder how come that discrepancy? Thus, this whole debate that continues to loop.
So, if a more demanding engine condition and engine design on the oil; comparing manual specs outside of the US? Yeah, I’m down for going up a grade. It’s not going to hurt anything if maybe a slight fuel economy drop. How you drive it will have more impact than a single grade of oil change.
.02
For actual racing, yeah, why run thicker than necessary? If anything the rule is to prevent people from going down in viscosity for extra power at the cost of quicker engine rebuilds.A friend of mine tracks his Fit. Champcar endurance series. I'm sure they are using a 40 grade but I'll find out....
EDIT: they run M1 5W30 for this...however, for some racing series they run the recommended 0W20! In that series rule state you have to run what the manufacturer calls for so what's on the cap is what they run. Would anyone know? Of course not but rules are rules.
Got to be the reason.For actual racing, yeah, why run thicker than necessary? If anything the rule is to prevent people from going down in viscosity for extra power at the cost of quicker engine rebuilds.
