Originally Posted By: VeeDubb
I noticed the latest Sienna uses 235/60/17 tires as compared to 215/65/16 in the previous generation. Why? We are talking about a minivan here so carving corners through mountain roads is not exactly a priority. Plus you give up ride comfort, better winter traction, better MPG, and cheaper tire replacements. Somebody explain the logic to me.
As was already noted earlier, the two tire sizes you mentioned have the same sidewall height, so comfort should not be affected much.
Is the new Sienna heavier or does it have a higher load carrying capacity compared to the old one? Maybe that necessitated tires with higher load index. Also, it looks like 16" rims are no longer an option on the new Sienna, so possibly it has bigger brakes.
In general, 235/60 is still a decent balloon with plenty of rubber between the rim and the pavement.
Pete you are right that 60 is a decent balloon size. I guess I should have asked why the trend is toward a lower profile bigger wheel even on vehicles that should prioritize the opposite of what bigger wheels are delivering.
The new Sienna is about 100lb heavier curb weight. The ability to accommodate bigger brakes is a good argument that I hadn't considered since one of the complaints of the old Sienna was that brakes were small for the vehicle.
Still, it's crazy to me that Toyota gives you the option of 18 and even 19 inch rims on
Siennas.
Edit: The Sienna SE comes with 235/50/19's
