Who's using 10W-40 for the Summer?
Quote:
Courage to use 10W40?? I thought I'd seen everyhthing dumb there is on BITOG but this takes the cake. What would it take to run 40W70?
Sprintman,G'day stuffed I'll be!
You're acting like a real knocker. Your remarks aren't good oil, they sound like galah drongo I am gobsmacked that you are talking out your freckle. I'll bet you drive a feral painted pink. Now don't get mad as a cut snake, but it sounds like you're a bushy who has been in the outback too long.
But,maybe we can become mates and sit down and yabber while we down a few butchers, a bottle of plonk, and snags.
Hooroo!
I've used 10w-40 for the past 2 years in my 96 sunfire to slow down oil consumption. on this past oil change, I've used 15w40 as top up. I like the 15w40 delvac top up, haven't had to add any oil since.
My (US spec) 2004 Subaru Impreza WRX owner's manual oil viscosity chart actually has 10W-40 listed for normal use in all temps that 10w30 would also be appropriate. Off the top of my head, this was for anything warmer than 0 deg F. I wouldn't use it though.
The manual also has a recommendation for the use of thicker oils in extreme desert climates and for towing use. They included 20W-40, 20W-50, 30 wt, and 40 wt.
Im going to switch to a 40 weight for an OCI, just picked up some of the Valvoline on sale at kmart to do it. Just like others, im doing it to see if consumption will go down.
I generally see no reason to use 40 wt except for some engines that specifically call for it and also maybe a quart or 2 to thicken it up just to lower consumption. That's itt.
I will probably drain 1 qt. of the mix in there now (5 qts. of Red Line 5w30, 1 qt. of Red Line 10W-40) and add 1 qt. of Red Line 10W-40, when the ambient temps stay steadily above 65* F. This is just to bring the 100* cSt up closer to the middle range of what my engine (Gen 3 LS1) calls for (and to add a slight HTHS and fresh add pack boost). I would normally accomplish this by changing the filter, but don't want to "waste" my EaO 32, as it will only have about 4K miles on it at that time.
I don't know what kind of a vehicle you drive but you say you want to go away from the manufacturer's required 5W30/10W30 oil so I would assume you are driving a fairly new vehicle. In the USA most gasoline engine cars, SUVs, vans and light trucks have required 5W30, 10W30, or even 5W20 oil for a long time now. So I don't know why anybody would even want to put 10W40 oil into a modern car or truck. Oftentimes in owner's manual's it is stated NOT to use 10W40 oil.
In the case of my own car which is a 2003 Saturn Ion in my owner's manual it is stated that 5W30 is preferred, 0W30 can be used in extreme cold, and 10W30 can be used (warm temperature only) if 5W30 cannot be found. The first Saturn car I even owned straight 30 weight oil was allowed in warm weather but now straight weights are not allowed. In the case of most gasoline engine Ford and Honda cars and light trucks 5W20 oil is either requirred or preferred. I know a woman who bought a Honda Civic and in her manual it stated that 5W20 was the preferred viscosity but 5W30 could be used if 5W20 was not available.
It is best (especially if a vehicle is under warranty) to use what the manufacturer requires. If I owned a newer Ford pickup truck I might be willing to use 5W30 in the summer (if it was allowed in the owner's manual) but I would use 5W20 in colder weather. I sure as heck would not stick 10W40 into it.
It fact, I don't see a lot of 10W40 oil on the shelves. It is mostly 5W20, 5W30, and 10W30, with some diesel engine oils that might be 15W40 or 5W40 and some oils for European type cars.
If 10W30 is allowed in the summer for your vehicle why not just use 10W30? And then you could use 5W30 in the wintertime.
I'll be running GTX10W40(SL rated, picked up for $1/qt) in my Cherokee for the summer. I might run it in my Wrangler trail rig too. I usually use Delo SAE30.
Quote:
Ownwers manuals are for people thet dont know any better, we all know better, thin oil is for CAFE standards.
So what would your opinion be of using 10W-40 in a car where the owner's manual lists 10w30? The car in question would be in good mechanical condition with no oil usage and have good oil pressure.
That may qualify as one of the most ignorant posts on here lately. And that's saying a lot considering some of the stuff posted lately.
Consider thick 30s too. I really like Delvac 1300S 15w40, it did not bog down my engines like other 15w40s. but I'd love to try Delvac 1300S in 10w30. It exists, right?
Quote:
Quote:
I use 15w40 (HDEO) in my Acura Legend year-round.
That's interesting because I'm guessing Acura recommends a thinner oil. Have you had any adverse effects of using 15w40?
According to the owner's manual, "lighter oil" was not recommended...at least not in 1987.
(sorry for the lousy scan)
Perhaps in later years, a change to 5w30 was recommened. There's been arguments on some of the Legend forums that all C27A engines should use 5w30, but no Acura dealerships that I've talked to can produce any kind of documentation that states Honda makes this recommendation retroactive to earlier model years. So, I just stick to what the owner's manual recommends.
Adverse effects? I'd have to say, none that I can tell. This engine has had either 10w-40 or 15w40 its whole life. At 378k miles, I'm not too worried that this is the wrong grade to use.
I would have to say the one benefit to running HDEO for the last +100k miles is it has eliminated the annoying tappet noise that's inherent to high mileage C27A's.
