who makes1/2" drive 7/8" extend deep well sockets ie at least 6" useable depth
only one I can find is by Reed and is like $60 or more...need an extra long 7/8" 6 point socket...need it for a special bolt/nut..a standard deepwell does not come close...anyone have a source they can pass on...usual places say they have no idea where to get one ie NAPA, Lowes, Home Depot, HF, graingers, fasteners etc...
22 mm is only 0.009 inches smaller than 7/8. 22 mm = 0.866 inches, 7/8 inch = 0.875 inches.
Maybe if the 22 mm does not fit, take about 0.005 inch off of each side of the nut with a milling macheine, or even something else like a belt sander, or file.
Even just touching the corners and flats with a fine file will possibly get you smaller.Its crazy that sometimes one flat or corner on a fastener needs a little massaging
If you have a micrometer, or a dial-caliber, measure the distance between flats.
If not, if you have a 22 mm 6 point closed or a 22 mm open end wrench, try it on that nut and your know if you'll have to slightly modify the nut to use the 22 mm socket.
the bolt is 22.3mm 22mm will not fit tried two different 22mm wrenches and 22mm socket.
i really hate taking a file to the nut as it has a coating and will probably rust....
GP Sockets are great, here is a 7/8 extra deep
GP Website with dimensions.
https://www.gpsocket.com/products/product.phtml/2028XD/
Amazon link should be $28
https://a.co/d/7t5mUcV
Seems like might only be 5" OAL? Specs claim 12.7" cm and Rufus says 4.4" which might be interior depth of a 5" OAL?
OP if you want cheap and don't need full broach, lop off the sq drive end, section in some pipe and weld it back up. You could also cut the sq drive off one socket and slap another on top of it, but you'd need to align the interior hex over a coupling nut before welding.
GP is impressive. I emailed them with a tech question and they responded right away with an answer. I asked how thick of a bolt would pass thru the socket up to the drive section and they answered right away
Just be advised that if you buy Grey Pneumatic from an unauthorized reseller, like Amazon, you'll get no warranty. It's clearly spelled out in their warranty terms.
https://www.gpsocket.com/warranty.phtml
IMPORTANT NOTE: GP manufacturers’ professional and industrial tools which are sold through the professional marketplace. GP recommends that its products be purchased from its professional authorized dealers in order to assure future support and warranty service. Unauthorized sources could include but are not limited to: Amazon, Bonanza, Ebay, Craigslist, Newegg, Rakuten, Walmart, Sears or any shopping search engine. GP recommends that you check your source of purchase for their service and warranty policy before purchasing. GP and its authorized distributor network will assume no service or warranty liability for products purchased from unauthorized sources.
I’ve seen where someone needed an extra deep socket, bought a cheap one from HF, cut the top off, and welded a pipe between the two ends. You have to cut it off close to the top so when you weld, you don’t take the temper out of the wrench end.
