Who made this filter?
Apple Valley, California
I was goofing off in the desert today and wound up in Hinkley,Ca. BTW this is the town that the movie Erin Brokovich was about. No I did not drink the water.
They have a small store there so I stopped to grab a Coke.
Wandered around a few minutes and in the back between the City Star oil and the Crack pipes they had a stack of oil filters.
I found the one that will fit my Jeep so I bought it. It was $3.49
It's a Carlube Lubemans Choice #M4670. The Purolater # for my Jeep is #14670 so they are basing their #'s off of Purolaters numbers.
The can is real thick like a Mobil 1 and the filter is very heavy. The threaded end is shrink wrapped to keep it sealed.
No where on the filter or box does it have a country of origin.
Stamped on the top is "water tested 10/16/09". The bypass valve hangs down from the closed end.
Has manufactured & certified by qs9000/iso9002 system on the box.
I wonder if it's Chinese?
shoulda bought two so you could cut one open!
does the logo look like this?
w/ a quick google search i found www.carlube.co.uk, a UK based brand of motor oil, and other fluids. though can't find mention of filters...
interestingly (to me anyhow) when i used their tool to recommend an oil for MY car('05 Dodge Neon), after changing the brand to Chrysler(which is how they were sold there), it recommended their semi-syn 10w40! here they were spec'd for 5w30 most yrs, and my '05 5w20.
I tried to squeeze the filter to try to bend it. not going to happen it's tough. the instructions say to tighten it 1 full turn with a wrench vs are american filters that say no wrench.
That should be real good for the inside of the filter.
