Originally Posted By: Cardenio327
The "check engine" lamp should switch off in 3 trips.
To completely erase the code from the memory will either take 40 or 80 trips, depending on the severity of the code set.
This is reasonably correct. I can't find the exact numbers just now, but what you say sounds right.
I wouldn't erase the codes with a scanner, some of the monitors can have difficulty resetting themselves after being erased. I would just let it switch the lamp off on its own.
Agree.
To see if any monitors report "not ready": Turn the key to "II", and wait 15-20 seconds. If the MIL simply goes off, then all monitors are "ready". If it begins to blink, then at least one monitor is "not ready".
