throttle body cleaning on a CRV
Pa
Couple of questions on cleaning the throttle body of my 2014 Honda CRV .
First one is it ok to use Amsil powerfoam on a lint free rag , was not planning to spray it down it .
Was planning on doing it while still attched disconnecting the battery first , hoping to avoid codes / idles issues after the cleaning .
What the best method for avoiding the codes or idle issues , just letting it idle after cleaning for a while like 10-15 minutes ?
Hoping not to have the dealer do it they charge a lot for a simple process imo .
There's a relearn procedure that must be performed after the throttle body is performed. There is a function in the scan tool to reset the throttle plate position, followed by performing the idle relearn.
I've done it both connected to the car (with the battery disconnected), on the 2.5 in the Camry, and disconnected (on my old 3800). If it's a heated throttle body that has coolant running through it (as I assume most are these days) doing it without removal prevents another failure/coolant leak point. I just used CRC throttle body cleaner, and cleaned the MAF sensor with the special MAF cleaner, while I was under the hood. I think the Toyota procedure involved various shifts from gear and to park, but they both idled better after the cleaning (after a kind of scary long initial crank). And, it should relearn the idle naturally over time, even if the relearn procedure doesn't go exactly as expected.
Soaking a rag with brake cleaner and then sticking it in there is the cheesy way you see people do on YouTube.
I always take the throttle body off the car to clean it.
I like cheese. I also like not going through leaking coolant things. I've cleaned many with microfiber rag, open fully (slowly) spray a bunch, wipe everything etc.
No issues. If I need to take it off for some reason then it will get done from the back also.
Thnaks for your thoughts guys .
On my 2002 Trailbazer I remove the throttle body after checking to see if its dirty in there.
For that ride just put it back on and let it idle for a while and all is good .
Was trying not to remove it in the Honda and open any cans of worms .
Left it go 80k trying not to fix anything if its not broken .
The ide has been a little rough latley and the throttle body has not been cleaned since I got the car new .
Dealer tried to tell me their service and it was not cheap a couple years back.
I dont have a scan tool to relarn the ide etc .
I'm interested in this as well for a 17 and 10 CRV, but don't have the special scan tool.
Looks like it isn't too hard with the proper tools, but can open a can of worms without.
Bob
My 2010 Ford Ranger’s throttle body is plastic. I cleaned it thoroughly with Amsoil Powerfoam. It ran with high idle rpm and between gear shifts the rpm did not drop anywhere near as fast as it should have. I eventually learned that the throttle body had a black, thick paint-like coating that my cleaning removed. There was a significant gap between the throttle plate and housing that caused the problems. I replaced the entire throttle body and all was well. Be very sure that there is no similar coating on your before cleaning it.
Did this a few times on my 13' CRV. Held open the butterfly with a piece of paint stick. Then used CRC throttle body cleaner with a piece of scotch brite to clean it up. Metal throttle body. No harm was ever done. Upon start up, it does throw codes, so I would just buy a cheap scanner with the delete feature. Huge difference in idling after doing this.
