Takes a bit more than a simple engine to get a reliable car. Buying used is always a gamble—and if you are trying to go back this far, you may find all sorts of problems. They may be minor ones, but I’m not sure if you are only worried about engine problems—or full out reliability.And if not, how far back in time would someone have to go to get a simple engine?
I agree. Back before VVT, a performance cam was always a trade-off between Low end torque and High end performance. VVT solves this issue.
Does the "Easy Spin" compression release on the intake cam lobe count as variable cam timing? Came out in 1961! The old Pulse-Jet carb mounted directly on the gas tank=Direct Injection. Ignition coil mounting holes are slotted to adjust to adjust coil to flywheel distance and the flywheel key sheared when you hit something=Variable Timing. The carbon build-up on head and piston from leaded gas=Variable Compression. Just asking-LOL. I miss those old Briggs.
Is the 4-runner still port injected? Toyota went with the dual system in a lot of their vehicles back in 2017. But maybe the 4.0 is still strictly port injected? They do have variable valve timing, with a split system mechanical actuators on the intake side and electric on the exhaust (unless I’m getting that backwards). And I believe the 2023 4-Runner went with a 4 cylinder turbo as their main engine?The Toyota Four Runner is about as old school as you can get, even the 2023 model.
It's port injected. 2023 does not have a 4-cyl turbo.Is the 4-runner still port injected? Toyota went with the dual system in a lot of their vehicles back in 2017. But maybe the 4.0 is still strictly port injected? They do have variable valve timing, with a split system mechanical actuators on the intake side and electric on the exhaust (unless I’m getting that backwards). And I believe the 2023 4-Runner went with a 4 cylinder turbo as their main engine?
Chrysler products with the old 3.3L and 3.8L IMO.Are there any vehicles manufactured today that have the following:
1. Multi-Port Fuel Injection (instead of direct injection)
2. No Cylinder Deactivation
3. No Variable Cam Timing
4. No Variable Valve Lift
..... to go to get a simple engine?
The CVT kills the deal.my little 1.6L Nissan/Renault 4 cylinder is **** reliable.
This, and VVT doesn't seem like it's that big of a deal to fix. Just figure on replacing the solenoids as a maintenance item at some point.Due to emissions requirements, you likely won't find something ne without some sort of variable cam timing.
Basically, you want 90s tech. And 90s performance. Weak, slow, thirsty.Are there any vehicles manufactured today that have the following:
They still put them in the Maverick but you have to get it with the hybrid system. When my dad was in the market for an Escape 2 years ago, I made sure he got one with the 2.5L and neither of the EcoBoost options.The Ford 2.5L N/A for many years has been in many Fusions, Escapes ect. until just recently. No GDI, no turbo, 180 or so HP It does have VVT. My lady friends Fusion with a 145K is still strong and uses no oil.
Good jobThey still put them in the Maverick but you have to get it with the hybrid system. When my dad was in the market for an Escape 2 years ago, I made sure he got one with the 2.5L and neither of the EcoBoost options.
