Which oil to chose?
Wyoming
I have a 2013 Mazda CX-5 that requires 0w-20 synthetic. My normal commute consists of 3 miles of city driving followed by 47 miles of highway each way. I drive easy as I'm looking at fuel economy. I live in Wyoming at 6000+ feet in elevation and where it is possible to see -30 degree weather in winter. I change my oil currently at 7500 mile intervals.
0w-20 oil is not very common around here so I will probably buy online. Looking at Amsoil Signature Series, Eneos synthetic, Pennzoil Platinum, Mobil 1 Advanced Fuel Economy, or Red Line synthetic. If you know of one that I didn't list that might be better, let me know about it.
Mobil 1 .
An BTW how far to the nearest Wal-Mart ? They usually have a good supply of Mobil 1 in all weights.
Well looks like I'll do Mobil 1 again since it seems to be preferred. According to Autozone.com it's not in stock but I can order it at least. Plus it appears they have a $10 off coupon for a 1 gallon jug or 5 qts.
Originally Posted By: tig1
Mobil 1 0w20 is an excellant oil and good for longer OCIs. But ordering on line???
I don't often agree with tig however in -30 temps Mobil 1 Advanced Fuel Economy 0w20 is one of the thinnest 20 grades available so at start up the oil should flow and warm up pretty quickly.
Pennzoil platinum is also a thin 20 grade and a possible option if easily available. Beats ordering online
Is 0W-20 a must in your vehicle?
5W-20 or Mobil 1 0W-40, can they be used?
If so, they will run when it is cold.
If not, make a drive to some other Walmart, even if it's a long one, and stock up on 0W-20; get a big stash. Or why not order online? There are bound to be some decent oils that fit the bill.
I suppose your vehicle is under warranty.
0w-20 is recommended and says in the owners manual that 5w-20 can be used but must be replaced with 0w-20 at the next change.
Napa is here as well, though they are just like Autozone and would need to special order it.
There is a Honda/Toyota dealership here and I might check to see if they have any and at what price.
Antifreeze should be fine, I just bought the car in July though I have already put on a few hundred miles short of 15,000 miles.
