Straight to the point as always eh mon ami.quote:
Originally posted by pscholte:
GC 0W30
GC 0W30
Hehe, true, our summer wasn't too hot this year, but even still, my LT1 really heats up the oil a lot (close to 300 degrees for sure) so that's why I would probably see better wear in the summer with a 40wt oil. I'll have to see how GC 0w30 handles the hot summer months next year to decide if I'll keep using it or switch to something even thicker.quote:
Originally posted by TooSlick:
Up in Canada where the summer is about 2 weeks long, I'd just use the 5w-30 year round.
I have considered the Mobil 1 mix, however I don't like the idea of ending up with an oil that's too thick at the low end, which is what would happen if I mixed in 15w50 with 5w30 M1.quote:
Originally posted by buster:
Patman, I'm surprised you don't want to try Delvac 1 in the summer months for your LT1. Or a mix of of M1. It's readily available.
I truly think if I could find a 0w40 oil for my Firebird that is around 13cst at 100c, it would work out very well for me. It would have to remain shear stable though, I don't want something that's going to thin out to 11cst in 10,000km. If GC 0w30 remains very close to 12.2 cst in my 10,000km intervals then it might just work out to be the best all year round oil for me and then I wouldn't absolutely need to switch to something thicker in the summer. Another alternative for me would be to install an oil cooler, as that would keep the oil temps lower in the heat, and then lessen my need for a thicker oil under those conditions.quote:
Originally posted by sprintman:
Patman if you can get BP product a low/mid 40W is Visco 5000 5W50 13.95cSt @ 100C (ASTM D445), Pour -42C (ASTM D97) and cranking @ -25C 3330 (ASTM D5293). I believe GC is looking good mainly because it's a thicker 30W but that will open up a can of worms for sure. If we had a 12.4 30W (I'm looking) it would be wow, how good is that but woe betide if it should be a 12.5 and a 40W. Obviously ridiculous. Too much time here is spent looking at 20/30/40/50W et al as if theres some magical jump between them. Think of this, we have a range of XW20 to XW70 generally available worldwide so the actual mid point is 45W. So a 40W, let alone a low end 40W cannot be classified as a thick oil. Just my two cents worth (replies should be interesting??)
The problem is finding it though, as the only oils our Esso stations here carry are the cheap dino stuff and Mobil 1.quote:
Originally posted by userfriendly:
Your wait is over> Esso XD-3 0W40, and its a PAO.
In USA Exxon XD-3.
I'd love to have a bigger motor under my hood, but it's not going to happen on my budget. Ideally I'd love to have a nice mild 383 stroker LT1 in my 95 Firebird, something that makes a ton of torque but isn't so radical that I couldn't drive it everyday. I should've just stuck with my LS1 f-body though, it made about 100 more horsepower, yet got better MPG and I had not even changed a thing inside the engine so it could have remained very reliable for a long time.quote:
Oh well, the sooner you wear that engine out, the sooner you can put a real one under the hood.
Do you have a GM performance parts catalogue?
Nope, running 11.9s won't require a cage at the two tracks I run at, one is IHRA, which necessitates a cage at 11.49 or quicker, and the other track just lost it's NHRA sanctioning, so they are pretty lax on the rules and I know of a few guys running 10.9s with no cage! (not smart, but they are getting away with it)quote:
The 68-73 307 chev was the best one ever built. 283's bore, 327 crank.
there's nuthin' wrong with the Olds 307, but the 403 is a disaster waiting to happen. Too light.
Patman, a 383 might just put you into the 11sBad, need roll cage and about 20 other changes including frame joiners....
Oh yea, and a poor boy locker. Welded diff gears and c-clip eliminators
