First off, hello Bob is the oil guy forum! I'm very excited to be a new member of this knowledgeable community! I've browsed here from time to time, reading topics topics discussing motor oil or small lawn equipment engines. Now I am here to seek your advice.
I am about to get my hands on a brand new 2017 VW Passat with the 1.8 TSI which has a turbocharged, direct-injection 4-cylinder (compression ratio 9.6:1). Having been in the diesel game for years without a gasoline car, I want to make sure I'm not going to screw up and use the wrong grade of gasoline in my new car.
VW states the car should be used with regular gas having a minimum octane of 87. No matter what, never ever go lower than 87, they say! Additionally, VW gives no recommendation or implies no gain for using higher than 87 except for in one discreet location: their website's spec sheet for the engine states that the maximum 170 horsepower output was "achieved using premium fuel," whatever that means. Can the 170 HP be achieved with regular,too...who knows? I don't really care either.
What does bother me is that where I live all regular grade gas sold at the pumps is 86 octane, not 87, due to the altitude (3300 feet above sea level). Where I want to fill (Costco--clean pumps, cheap, fresh fuel, and Top Tier!) the only grades offered are 86 octane and 91 octane.
Since I wouldn't want to violate the octane requirements for my new turbo VW, I see three different options:
1. Fill with 91 octane
2. Fill 20% 91 octane followed by 80% 86 octane with each fill-up
3. Abandon Costco and buy mid-grade 88 octane elsewhere
I would prefer option #1 since I trust Costco and mixing grades of gas sounds like a pain. Plus, I'm not sure I could achieve a homogeneous mixture of 86 and 91 in the tank every time anyways. This (maybe?) could cause troubles for the car if it briefly ingests small, unmixed portions of 86 when it wasn't expecting it. I know the knock sensor would react and pull timing...but that is a reaction to knock or detonation, not absolute prevention of it!
The only concern I have with burning 91 all the time is that I've heard it might cause carbon buildup inside engines not intended for premium, which is something I do NOT want to have happen. If I burned 91 for the life of this car, would the engine likely develop abnormal in-cylinder carbon deposits?
Thanks,
TurboDieselPoint
