Am I crazy for spending extra on 93.5 Octane premium when the mid range in this country is 90.7 Octane?
So I am currently in Germany.
My 2023 Armada "recommends" Premium.
In the US thats a minimum of 91, so this is what the recommendation is for.
Yesterday just drove from Kaiserslautern, GE to Strassburg going about 100 mph much of the way. (and back)
This was a welcome opportunity to "blow out the crud" out of my engine as I do a lot of very short trips , and its a DI engine.
Given these speeds I want to have the best fuel available.
But I am not at sealevel ( and every 300m altitude reduce your octane need by 0.5 Octane I once read.
Its cooler weather.
And the lowest rgade they sell here is 90.7 Octane (translated to US units) it costs about $7 per gallon anf the Premium is 93.5 Octane and costs about $8 per gallon.
I had been using the "mid range", which is their lowest grade, reasoning that my 91 recommended, car can handle 90.7 readily, which is nearly the same rating , the 90.7 Octane here is basically like maybe California Premium.
And that should be good enough, especcally as the car is also stated to be able to handle 87.
And its winter.
And I am not at sea level.
Still I seen several studies where vehicles had more power , almost regardless of the stated Octane requirement, when filled up with higher Octane.
And I saw one study years ago where vehciels had higher internal wear if run with the lower grade vs a higher grade even if cleared for the lower grade.
and I do go over 100 or even 110 mp regularily.
So lately i started to spring for the premium.
Makes me feel better, but it may not be rational at all.
What does the hive think?
Its cooler weather.
And its winter.
