Originally Posted By: CATERHAM
HTHSV trumps the KV100 spec'.
If you know the HTHSV of an oil you can ignore the KV100 spec'.
The reason is because the kinematic measure doesn't take into consideration the viscosity-pressure coefficients of different oil chemistries.
Even though the HTHSV is usually provided at 150C, the viscosity change with temperature is virtually linear from 150C down to 100C and to even lower temp's with light oil grades.
The other viscosity factor that one must take into consideration is the viscosity index of an oil.
For example, if two oils have the same HTHSV and the same VI's they will have the same operational viscosities at all temp's down to at least 0C regardless of what their respective KV100 spec's are.
The subject was discussed in detail in the following thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2276634&page=1
This question comes up a lot. I think the above thread should be posted on the BITOG Home page in the Additional Reading column, with the simple title "HTHS viscosity trump's the Kinematic 100C spec'".
Thank you for taking the time to repost for me. I will read it now. Sorry as well for asking a redundant question.
