that Pennzoil Platinum 0W20 and Quaker State Ultimate Durability 0W20 are the same oil? Here is a comparison of their data sheets:
Code:
Test PP QSUD
Grade 0W20 OW20
API Svc SN SN
ILSAC GF-5 GF-5
ACEA A1-02 A1-02
Gravity, API 34.8 34.8
Sp. Gravity 0.851 0.851
Vis, 40C 42.6 43.6
Vis, 100C 8.39 8.39
Vis Index 175 175
Flash Point 224C 435F (224C)
Pour Point -48C -48C
MRV Viscosity 17.5K 17.5K
CCS Viscosity 4840 4840
HT/HS Vis 2.6 2.6
Noack 14 14
The only difference in their data sheets was that the QSUD Flash Point was expressed in degrees F rather than degrees C. However, when converted, 435F = 224C.
Last time I checked at WallyWorld, QSUD was about $3 per jug less than PP. If their the same oil, this would make QSUD a best buy.
Code:
Test PP QSUD
Grade 0W20 OW20
API Svc SN SN
ILSAC GF-5 GF-5
ACEA A1-02 A1-02
Vis, 40C 42.6 43.6
Vis, 100C 8.39 8.39
Vis Index 175 175
HT/HS Vis 2.6 2.6
Noack 14 14
