I'd install it exactly as the FSM says to do including the recommended sealant. Toyota FPG is good, as is Honda Ultra Flange II and the Permatex Right Stuff equivalent.
I agree with with you. I was thinking the same thing - he needs another mechanic. To be honest, I did not look up the procedure for the job as I was just commenting on the pump and o-ring. My shop will use whatever means the OEM says to do be it gasket or sealant. My only point was that pump and o ring seal will work fine and actually the last lexus I did had the same exact style o-ring. I would not recommend using sealer on a part with a channel for an o-ring. RTV is only to marry flat surfaces together.I sort of agree, but what I am thinking I am hearing is that Toyota wants the mechanic to use the sealant, not the O-ring in this case. The OP is thinking that the mechanic cannot be trusted to do a meticulous job and therefore would prefer an O-ring or a gasket. And I get that. I have used Hondabond enough times to know that it can make a mess, and using the right amount can be a challenge... but that would not mean I am going to go without. In my case, when I am out of my depth, the cars go to a specialist Japanese/Asian car shop, and I trust the job will be completed in workmanlike fashion. The point is that I am not going to McGuyver a solution because of nervousness about a mechanic... especially in a Toyota workhorse where you might not be back in the engine for another 100K.
The RTV does not go into the groove, it sits just outside of the groove. These pumps seal just fine using RTV as long as you follow the instructions.I agree with with you. I was thinking the same thing - he needs another mechanic. To be honest, I did not look up the procedure for the job as I was just commenting on the pump and o-ring. My shop will use whatever means the OEM says to do be it gasket or sealant. My only point was that pump and o ring seal will work fine and actually the last lexus I did had the same exact style o-ring. I would not recommend using sealer on a part with a channel for an o-ring. RTV is only to marry flat surfaces together.
Thanks critic, after research I’m going to go with 103 Toyota FIPG.The RTV does not go into the groove, it sits just outside of the groove. These pumps seal just fine using RTV as long as you follow the instructions.
https://www.toyotanation.com/posts/14003826/
Thankyou so much for this lolThe RTV does not go into the groove, it sits just outside of the groove. These pumps seal just fine using RTV as long as you follow the instructions.
I had to look it up lolThe RTV does not go into the groove, it sits just outside of the groove. These pumps seal just fine using RTV as long as you follow the instructions.
Is 103 the specific Toyota FPIG called out for a water pump?Thanks critic, after research I’m going to go with 103 Toyota FIPG.
“We recommendIs 103 the specific Toyota FPIG called out for a water pump?
That’s from the diagram from aboveIs 103 the specific Toyota FPIG called out for a water pump?
with a help of a user we were able to source the manufacturer recommended FIPG inside the bolts but outside the channelThe rubber seal that goes down in a groove would be the most convenient way. Even better if it's made out of silicone.
You may find that less expensive or easier to procure than the Toyota part number. Or not“We recommend
Aisin part # AB1207B or Toyota part # 00295-00103.”
You’re a genius!You may find that less expensive or easier to procure than the Toyota part number. Or not![]()
That way you don't get overflow inside the waterpump where it can flap around like a flag, break off, and then go block a valve or channel in the heater or radiator. Or so the theory goes.with a help of a user we were able to source the manufacturer recommended FIPG inside the bolts but outside the channel
Interesting, to me it looks like the channels for an o-ring but according to the manual the channel is to catch spill over FIPG.
It's not an o-ring gland or they would but on o-ring into it. It's a FIPG sealing gland.I would use the O-ring as long as the 2 mating surfaces are flat, and no seams. It seems crazy they would recommend a FIPG when they have an O-ring groove?
Toyota dealer will generally have fresher stock. RTV expires quickly, even when unopened.You’re a genius!
easier to procure (amazon official Aisin store)
Thanks!
