70 Lincoln with a 460, points converted to a Pertronix Ignitor II hooked to a MSD coil. The coil has switched +12v to it.
If I go back to using points,
1. Can I use the new coil, or should I put the old coil back on?
2. If old coil, then do I need to connect the old power source that is a ballast resistance power source?
background - see this thread old thread on BITOG
