I need some old school schooling!
I have a 70 Lincoln Mk III with a 460. It currently has the original style coil/dist setup. I have replaced the points with a Pertronix II unit. My understanding is that the wire that's connected to the plus side of the coil is a "resistor" wire that's connected to the ignition switch.
Please explain the old style coil/resistor wire setup/theory and troubleshooting.
Specifically:
1. How do I check the resistor wire with the meter?
2. How do I check the coil with the meter?
3. Why are some coils 1.4 ohms, 2.5 ohms, etc. why the diff?
4. How do I check a plug wire/coil wire with the meter?
5. Can I replace the resistor wire with a 12v switched supply that has an external resistor inline?
6. Is it possible for the coil to work fine but when it gets hot it doesn't work right?
Thanks for the help guys!
Specifically:
