A nice bit of progress, I've got a connector installed on the display wiring.
The pins on that are surprisingly challenging to solder because of the tight pitch of 10 pins in a small space. Note my small hand for scale:
I even managed to remember to put the cable gland on before soldering any wires! Unfortunately, I forgot the plug backshell on the other half and had to desolder a couple wires in, thankfully a fairly minor setback.
If you ever need to solder something like this, the technique I used worked pretty well:
-- Tin the connector pins and fill the cups half with solder.
-- Twist and tin the wire leads
-- Dip the end of the wires in a bit of paste flux
-- Heat the cup to reflow the solder, letting the flux on the wire end do the necessary wetting and fluxing.
Because of the tight pitch, and bent fine point on the iron is super helpful. But that also means a fairly small tip mass and wetted area, so you'll want to run the temperature a bit higher than you'd normally consider. I like 400C within ±10-20C or so (~750F). This is hotter than I typically run, which I'm usually more in the 340-360C range. (660F neighborhood).
Tip temperature itself isn't really that critical, it's really about finding the balance between hot enough to get in and get out in a reasonable amount of time (2-3 seconds) without having things so hot you can't control them. I tried 450C and while it was super fast in any out, I was torching some insulation and the flux was burning off way too fast.
Besides, the 2 second rule is generally to prevent damage to fragile QFPs and other ICs on PCB. When soldering connectors, it's quite acceptable to run 3-5 seconds and get a tiny bit more heat soak in return for more control and neater work.
I like these cheap little connectors well enough I think I'm going to do another one on the other interface to the box that is for OBD interface (power/ground) and the sensor inputs (pressure sensor and RTD).
One advantage of doing a connector there is how easy it is to then run power to my pressure sensor-- I just need to solder a short between two pins on the connector. Easy Peasy. Then the pressure sensor gets 12V without any crimps or butt splices or other such complexity.
Ideally you would not use a 10 pin connector when you only need 5 pins. You'd either use a 5 pin version of the connector or the next size down for failsafing and such. But since this isn't going to be a production items (Lord knows that is NOT happening) and the only person dealing with these interfaces is yours truly, I think I can leverage the relative familiarity with the system.
Anyway, were almost to the point of being ready for full on bench test including the display! Exciting milestones are approaching.
