Where would I connect MSD to this ignitor Lexus
los angeles
I did an engine swap and the 2JZ has a distributor. What I want to do is hook up an MSD box to it. I don't want to rick damaging any wire that I don't need to, or burn out the ignitor somehow. Does anyone know which wire is the signal wire that I can use? Thanks https://portal-diagnostov.com/en/20...nce-lexus-gs-300-1994-system-wiring-diagrams/ I tried downloading, but it keeps saving as some svg file or something like that. I don't know how to convert to pdf. The ignitor is at the very bottom of the first picture. Thanks again.
to convert to pdf you need to print to pdf printer
You should have a printer called microsoft print to pdf
it may look different in older version of windows.
