Where to get an oil change Nashville
I am not in Nashville, so I am not sure.
Find a shop where you can watch when they are doing the oil change, assuming you know what you watch.
Is this for some sort of exotic car?
Same question.
Oil changes aren't often rocket surgery.
Though I taught my daughter basic auto maintenance including how to do an oil change she has now moved to an apartment in Nashville you’re not allowed to work on your vehicle in the parking lot and she does not have a garage therefore she will have to rely on someone to do the oil change for her
I was not insinuating that you or the owner were incapable.
I was just saying that oil changes are uncomplicated in most cases; even a local quick lube should do an adequate job.
I’d suggest Woodard Automotive on Dickerson Pike.
Havent had them change my oil, but I needed a set of brake rotors turned, and a friend recommended them. They did a good job.
Since then, I referred a friend of mine to them who needed rear axle seals and bearings replaced on his Titan, and my friend told me that they also took good care of him.
So I’m sure they can handle an oil change and other maintenance she may need.
Have her ask co-workers. Nashville is a big city so driving completely across town for an oil change isn't practical.
There's no reason to be afraid of the usual quick-change oil places either. They do hundreds of oil changes every day with zero problems. No matter where she goes, the biggest concern will be the up-selling she'll get and may not know how to respond. One way to potentially avoid that is to take it to a dealer of other models. Say she drives a Honda, so take it to a Ford dealer and use their quick-lane oil change. They aren't likely to upsell her on air filters, etc 'cause they don't have them available (easily).
