Where can i find Auto-Rx
MO
Im presently cleaning up my Engine. Im satisfied that one quart MMO in with the Oil is OK, but i may go an utoRX run this OCI, i wonder if i can run MMO in it too
My Biggest concern is the "Eating Of Gaskets." I need to get the Oil i have in there now, as B12 i put in Crankcase sure that was Harsh, but ive since added oil and MMO and all seems to be OK, so now i want to continue MMO and see if i can add AutoRX at same time, i dont think ill do the B12 again i did that to see if it would be a good way to start on some -possible- dirt in there, if it was bad, as of course i do not know
I use either Valvoline or SuperTech Valvline costs too much but they seem to be more than good enough for the job, and to keep my engine running nice forever.
Would you put AutoRX in same time as MMO, and where can i get Auto-Rx?
ARX is mail order only. It isn't necessary to add anything to it while cleaning.
Pour it in, and forget about it. Come next oil change, add MMO if you want at that time. (Some people do that.) Do not add ARX.
Run it til the next oil change.
You have put B-12 in your crankcase, then you put MMO in your oil, and now you want to add auto-rx.
I am just wondering if you put auto-rx in that you might come back and ask if it is okay too add Seafoam or Rislone.
It sounds like you are experimenting and if you keep adding different oil additives then how will you know which one did what or if you have a problem then which one do you blame.
NO !
