- Joined
- Nov 29, 2021
- Messages
- 5,387
This is a general question; in my case, could be specific to the 2004 Ford in the sig (3.0L Vulcan.) Pretty simple question, if I was a betting man, the light is more than likely on for both P0420 and P0430 at the same time. If I look at the length of time it takes to set until it clears, I'd say it is marginal (takes awhile to set vs setting very quickly.)
I am continually bewildered by good ol' YouTube. You'll see the occasional video, "Hey, I used this and my light went off!" Usually in relation to emissions . So, while it is a whole different thread to explore the relationship between HO2S/O2 sensor (not all are heated?) values and range of setting a P0420 and P0430 code, my specific question is the parameters in which a car's computer or ECU/ECM will actually un set the light once it goes on.
Also not sure if it would ever do that when both P0420 AND P0430 set; maybe one or the other? This thread is not specifically about the proper fix for P0420 and P0430; it is about when a MIL will turn itself off by itself just regular driving not attempting to fix anything. I think I've had that happen on OBD1 cars. I know it CAN happen on OBD2, or MY1996 and later, cars.
Experts about how this goes (when a MIL will sometimes turn itself off,) question of this thread is how/why!
Here's from our outing over the weekend when it came on. Again.. answers don't have to be specifically about "SCSM's Ford," How does this go. Thank you
